Old 06-29-2016, 08:54 PM   #11
TheHolders5's Avatar
So if I plug in to a 110 outlets it will run fridge?
2015 Cherokee 284bf limited
TheHolders5 is offline   Reply With Quote
Old 06-29-2016, 08:55 PM   #12
TURBS's Avatar
Originally Posted by northstar1960 View Post
Why do you need battery with shore power ? mine works when hooked to shore and no batteries . seems the converter takes 0ver
What I really meant is you need 12v as well on shore power.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-29-2016, 08:55 PM   #13
TURBS's Avatar
It better!
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-29-2016, 08:57 PM   #14
northstar1960's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
ok thought as much but a newbe may get confused
northstar1960 is offline   Reply With Quote
Old 06-29-2016, 09:24 PM   #15
I'll get it figured out!!! Thanks for the info.
Old 06-29-2016, 09:29 PM   #16
It's "generally accepted" that you shouldn't run your converter without a battery, as the battery acts as a "filter" to smooth out the 12VDC (which is made from alternating current) and a "cushion" for sudden load changes, like when you turn something on or off.
That being said, I just read a WYFCO installation and operating manual and it didn't say anything about running it without the battery.
2011 Traverse LT, 3.6L, FWD
fridge
