06-29-2016, 09:13 AM
Fridge
Will the fridge run off just the battery or do you have to have gas on or be plugged in?
2015 Cherokee 284bf limited
06-29-2016, 09:22 AM
If you have an rv fridge you need gas and battery for gas operation and for shore power you need battery.
Gas + battery for gas mode
Shore + battery for electric mode.
Sent from my SCH-R530U using Tapatalk
06-29-2016, 09:38 AM
10-4, that will work
No problem.
06-29-2016, 09:41 AM
We will be going on first trip in July so just try to find how to get fridge cooling down the night before.
06-29-2016, 11:55 AM
Most of us plug the RV into shore power and use electric side overnight.
Then switch to propane side while traveling.
06-29-2016, 04:43 PM
Sounds good, thanks
06-29-2016, 05:00 PM
Only those of us who store at home.
Those of us who store in a storage lot have to light off the gas the night before.
2011 Traverse LT, 3.6L, FWD
06-29-2016, 08:32 PM
That what I'm going to do, on gas how long will in take to cool fridge?
06-29-2016, 08:44 PM
Why do you need battery with shore power ? mine works when hooked to shore and no batteries . seems the converter takes 0ver
06-29-2016, 08:54 PM
So if I plug in to a 110 outlets it will run fridge?
06-29-2016, 08:55 PM
What I really meant is you need 12v as well on shore power.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
It better!
2015 Columbus 320RS
2008 2500HD Duramax
06-29-2016, 08:57 PM
2015 Columbus 320RS
2008 2500HD Duramax
ok thought as much but a newbe may get confused
06-29-2016, 09:24 PM
I'll get it figured out!!! Thanks for the info.
06-29-2016, 09:29 PM
It's "generally accepted" that you shouldn't run your converter without a battery, as the battery acts as a "filter" to smooth out the 12VDC (which is made from alternating current) and a "cushion" for sudden load changes, like when you turn something on or off.
That being said, I just read a WYFCO installation and operating manual and it didn't say anything about running it without the battery.
