Old 08-20-2013, 01:41 PM   #1
Fridge and slope
Hi, I have seen warnings in these forums about not running your fridge when you are parked on a slope (i.e. in driveway). Does that apply to residential 110 fridges or just ones that run on propane?
FYI: I picked up my new Georgetown 378 yesterday and am showing it off in my driveway with its (residential type) fridge running - am I getting myself in trouble??
jjansen is offline   Reply With Quote
Old 08-20-2013, 02:10 PM   #2
Brother Les's Avatar
Your electric is fine on a slight slope. The issue is with the propane flame going into the heat tube. If the flame is tilted it will heat the side of the tube and not go straight up.
How it works :: Propane Fridge Store
Brother Les
Old 08-20-2013, 02:21 PM   #3
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
HHHmmmmm? I thought it had to do with the gas in the tubes of the refridge? We need Herk to comment on this one.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 08-20-2013, 02:47 PM   #4
wneise's Avatar
With standard compressor fridges, the slope won't affect it that much. Absorbtion fridges need to be level for gases and liquids to mix/precipitate out properly whether it is on LP or shore power.
wneise is offline   Reply With Quote
Old 08-20-2013, 02:47 PM   #5
You didn't read the article did you? Heat (heat) turns liquid into gas, gas evaporates and returns to liquid (cooling effect). If there is no 'heat' (not going up into 'heating tube' correctly), the liquid would have difficulty to turn to gas. Herk will elaborate to the correct verbiage.
Brother Les
Old 08-20-2013, 04:00 PM   #6
X2. Not the flame.
fridge
