Old 08-10-2014, 03:18 PM   #1
Fridge concern
We have a new Cherokee tt and I do not see the drain tube coming out of the outside vent. It looks like there is a tube that is draining into a small tray inside the vent cover. Is this correct?
Pirateman98 is offline   Reply With Quote
Old 08-10-2014, 03:38 PM   #2
There should be a drain tube behind the fridge outside vent cover. When I bought my TT I had to route it out thru one of the holes in the vent cover. Most of the time they are just stuffed up behind the vent cover.
mbeldue is offline   Reply With Quote
Old 08-10-2014, 04:02 PM   #3
The tray MIGHT be OK. My home fridge drains to a tray underneath. The air coming across it to cool the coils also evaporates the water.
I'd just keep an eye on it. You can always route it outside if it starts giving you trouble.
2011 Traverse LT, 3.6L, FWD
Old 08-11-2014, 05:39 AM   #4
fonzie's Avatar
You are correct.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 08-11-2014, 06:18 AM   #5
Plain Old Member
Not sure of the brand fridge you have, but all the Norcolds I've seen have the tube going into a small pan between the back of the fridge and outer vent / panel near the burner tube. All the Dometics have the tube run through the vent panel to the outside. Not sure if the norcold works off evaporation from the small pan or what, but I have 2 units within 100 feet of me that are both like that. Even on the norcold, I'd reroute to the outside. No reason not to that I can think of.
Sent by ME
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-11-2014, 07:13 PM   #6
I think because it leaves streaks on the camper wall.
Old 08-11-2014, 07:14 PM   #7
There is a small black stopper in the end of the hose also. Not sure what purpose a blocked tube serves....
Old 08-11-2014, 07:18 PM   #8
Plain Old Member
Mines never left streaks. Doesn't drip down the side. It's in the shop now or I'd take a picture.
Sent by ME
Old 08-11-2014, 07:40 PM   #9
rattleNsmoke's Avatar
You sure it's a stopper and not a bug blocker?
rattleNsmoke is offline   Reply With Quote
Old 08-11-2014, 09:13 PM   #10
BandJCarm's Avatar
I have the black tube coming outside, but it has NEVER dropped one drop of condensation, ever.
Baffles me.
BandJCarm is offline   Reply With Quote
Old 08-12-2014, 07:09 AM   #11
Plain Old Member
Ever pulled the little clear piece out of the end of the tube or checked the whole tube for routing, kinks, or the connection to the drain behind the fridge. There are times the fridge just doesn't condensate much. If you're a weekend warrior and only run it for a few days at a time, very possible you won't see much. Take a little water in a cup or bottle and pour it in the catch pan under the fins in the fridge and check the tube for drainage.
Sent by ME
Old 08-12-2014, 10:56 AM   #12
cat1956's Avatar
Mine has a black vented plug to keep bugs out.
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 08-12-2014, 11:05 AM   #13
We have a Cherokee 27rr and after spending 7 days in it the little pan you are talking about was half full of water. I wondered what would happen after 2 weeks. I have never seen anywhere that you have to empty it but it would surely overflow.
comfun1 is offline   Reply With Quote
Old 08-12-2014, 11:21 AM   #14
It is not a blocker, It stops the bugs from getting in and blocking it. Look at the end closely. I'm sure that it has small holes for the water to drain out. Most of the tubes are some very thin walled plastic tubing. This tubing generally gets brittle and cracks. It should come down and bend back up like a sink drain. So that you will have water in the bend most all of the time. Otherwise you will get same outside air temp inside your refrigerator. Causing the inside temp to rise. I replaced mine with vinyl tubing when I pulled the refrigerator to put fans in the vent shaft.
OKI Marine is offline   Reply With Quote
fridge
