06-19-2013, 12:41 PM
fridge cool down time with fans
6pm.
06-19-2013, 12:42 PM
7 pm
8pm
06-19-2013, 12:43 PM
9pm
10pm
11pm fridge was to temp 32º
06-19-2013, 01:09 PM
Hey Turbo,
Can you elaborate a little on what you did and how you did it?
The pic's are great but I would like to know more.
many thanks,
Bill
2009 Flagstaff 8528 RKSS
2019 GMC 2500 HD Diesel
Pullrite Superglide 14K
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
06-19-2013, 01:26 PM
Installed a 80mm fan on fins .
If the fridge is on this fan is running.
06-19-2013, 01:27 PM
Installed two 60mm fans in filler panel on exterior of fridge.
06-19-2013, 01:29 PM
Close up of one external fan.
These come on with fridge on as well but I also have a switch to turn them off if its cooler outside.
Turbs
06-19-2013, 01:40 PM
Phat Phrog Physician
That looks like a Cooler Master PC case fan! Got several of those bad boys lying around, build confusers as a hobby. Where'd ya plug the 3-prong power jack in?
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
06-19-2013, 01:52 PM
Doc
Hot wire and ground to the un switched side of fridge light. For internal fan.
Outside fans get power from lower left of circuit board.
06-19-2013, 01:53 PM
Lower left
06-19-2013, 03:48 PM
Very cool Mod, Turbo.
I might just do this too.
Thank you for sharing.
Bill
06-19-2013, 03:56 PM
5 hour cool down time is pretty good eh ?
06-21-2013, 02:06 PM
What were some of the other variables? Did the outside/inside temp(of RV) stay relatively the same.....what was the ambient temp?
Where you using electric or propane?
Did you do the same comparison without fans?
I could swear I got similar cool downs without fans but I know the outside temp was 65 degrees so it is hard to compare.
06-21-2013, 02:18 PM
In side of camper was 80º
Outide wwas sunny at 6 pm to 930 pm
11 pm temp was 70
70% humidity.
A/c was noy on.
07-11-2013, 09:23 PM
I did Turbs fridge mods and it worked awesome. I was camping here in FL the past 4th of July. The temps were in in the 90s and my fridge was at 34 degrees all weekend. The biggest difference was how fast it recovered from opening and closing the door often. Great idea Turbs!
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
07-11-2013, 09:40 PM
Good report back!
07-14-2013, 09:17 PM
Originally Posted by f1100turbo
Good report back!
Turbs, I used the 120 mm fan I told you about on the coils. I zip tied it to the coils, it fit perfectly. I test the air flow by taking some paper and putting it against the outside vent. It sucks the paper and holds it up against the vent. The fan was a computer case fan.
2014 XLR 27 HFS
07-15-2013, 10:38 AM
Awesome!
Circulating the air makes a BIG difference!
07-15-2013, 11:12 AM
Steve Jackson
Can you explain the hot wire to fridge light a little more? Not really good at electrical stuff. If you have a picture that would be good. I'm more visual when it comes this kind of stuff.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
07-15-2013, 11:18 AM
If memory serves me correctly the hot wire that goes to the fridge light bulb is what I used.
This wire is hot as long as the fridge is "on".
The ground is switched via you lever to turn light on when fridge is opened.
So the ground wire went to the side of the switch which is always grounded.
I'll take a pic tonight with light cover removed and double check the answer I gave.
Turbs
