Old 06-19-2013, 12:41 PM   #1
TURBS's Avatar
fridge cool down time with fans
6pm.
Old 06-19-2013, 12:42 PM   #2
TURBS's Avatar
7 pm
8pm
Old 06-19-2013, 12:43 PM   #3
TURBS's Avatar
9pm
10pm
11pm fridge was to temp 32º
Old 06-19-2013, 01:09 PM   #4
fivecodys's Avatar
Hey Turbo,
Can you elaborate a little on what you did and how you did it?
The pic's are great but I would like to know more.
many thanks,
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 06-19-2013, 01:26 PM   #5
TURBS's Avatar
Installed a 80mm fan on fins .
If the fridge is on this fan is running.
Old 06-19-2013, 01:27 PM   #6
TURBS's Avatar
Installed two 60mm fans in filler panel on exterior of fridge.
Old 06-19-2013, 01:29 PM   #7
TURBS's Avatar
Close up of one external fan.
These come on with fridge on as well but I also have a switch to turn them off if its cooler outside.
Turbs
Old 06-19-2013, 01:40 PM   #8
Phat Phrog Physician
SabreDoc's Avatar
That looks like a Cooler Master PC case fan! Got several of those bad boys lying around, build confusers as a hobby. Where'd ya plug the 3-prong power jack in?
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
SabreDoc is offline   Reply With Quote
Old 06-19-2013, 01:52 PM   #9
TURBS's Avatar
Doc
Hot wire and ground to the un switched side of fridge light. For internal fan.
Outside fans get power from lower left of circuit board.
Old 06-19-2013, 01:53 PM   #10
TURBS's Avatar
Lower left
