Update 2: I think I'm on to something. Does anyone know what this is or the part number.
I know I had 12vdc coming in and that the thermo fuse had continuity which if tripped will cut all power. It looked like the positive supply wire and one wire from the Thermofuse went behind the chimney. It turns out that was one wire that was pinched back on itself and went to the main circuit board. It was covered in a loose black insulation.
Inside that is a small, silver thing marked "Microtemp" (first picture). That wire does NOT have continuity. It must have been very close to the flame. At the bottom of the second picture you can see metal prongs that clamped the wire and held it near the chimney. I'm wondering if the silver thing is to be near the flame/heat and was it too close.
