Old 08-14-2012, 12:10 PM   #1
Plowking's Avatar
Fridge Door Panel
My wooden door panel keeps slipping / falling out. It seems the bottom tray that snaps in to the fridge doesn't hold and I assume when I hit a bump while transporting it dislodges. i have tried reversing the top tray with the bottom but it still happens. Not only is this annoying but when it falls it falls directly onto the electrical shut off pull switch. This is now bent and I cannot chance shearing it completely off so I have totally removed the panel.
I know this is still under warranty but has any one experience this also?
Thanks in advance for any advice,
Plowking is offline   Reply With Quote
Old 08-14-2012, 12:19 PM   #2
Triguy's Avatar
Glad you are here and hope we can help you.
First thing - please let us know what your trailer is and what make and model fridge.
Now, I've personally never had a problem with the raised panels on my fridge, but others have. Here are two threads.
Watch your toes!
Wood Panel for fridge keeps falling off!
Good luck!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-14-2012, 01:21 PM   #3
Plowking's Avatar
Sorry...I am new to this forum and I see my signature was not attached. I have a 2012 ROO 23SS. I know it is a warrenty issue but reading your past posts it is good to see I have a solution for after warrenty.
Thanks again for you reply and past posts attachments...
C Breen
2012 ROO 23 SS
2012 Ram 1500
Old 08-14-2012, 01:33 PM   #4
Triguy's Avatar
No problem. You are definitely not alone. These falling doors seem to be a design or install issue. You and I have the same fridge and we haven't had the problem (yet - knock on wood) so not sure if its the design or the installation.
Let us know how it goes at the dealer.
Here's one more thread for you from another Roo owner.
233s wood panel in fridge door slid down -- 2nd Time
Scott
2012 Shamrock 233S
Old 08-14-2012, 07:21 PM   #5
Dave Lyon's Avatar
Fridge
That sounds dangerous Fonzie.
As you have noted it is a warranty issue. If the trailer was out of warranty I would probably fix it myself with Contractor PL or a similar product and permanently affix it to the fridge door.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
