Old 02-12-2019, 10:52 AM   #1
Fridge drain tube has plug?
My propane fridge isnít draining. Seems there may be ice in the drain tray. Went outside and checked. Found a small white tube/hose with a plastic plug in it. Why? Is it the drain? Why is it plugged. Tube is. Only about 1/8 inch diameter.
rogerkathy is offline   Reply With Quote
Old 02-12-2019, 10:58 AM   #2
A32Deuce's Avatar
Pull the plug and see if it drains.
A32Deuce is online now   Reply With Quote
Old 02-12-2019, 10:59 AM   #3
Not a newbie
Johnfort's Avatar
Pictures?
Johnfort is offline   Reply With Quote
Old 02-12-2019, 11:01 AM   #4
i think you are referring to the small screw in plug that is put in to prevent bugs from entering the drain line
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 02-12-2019, 11:03 AM   #5
Flybob's Avatar
Fridge drain is normally a 1/2" ribbed line. They have an end cap, but it has small holes in it to allow it to drain.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-12-2019, 11:04 AM   #6
Mr. Dan's Avatar
Yes... this ^^^^^. Iím sure that plug has holes in it. The fridge doesnít drain constantly. Mine only drains when I turn it off and it defrosts.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 14
Old 02-12-2019, 11:14 AM   #7
Not on Nor-colds . they have just what op describes. small tube with small white plastic insert . though it has a hole in to allow draining . Dometics have the type you describe
MR.M is offline   Reply With Quote
Old 02-12-2019, 11:22 AM   #8
Yep. Mine is a Norcold and it does have tiny holes in it. They were plugged. So now Iím just defrosting rest of fridge. Your collective speedy responses did point me in the right direction. Thanks to all.
Old 02-12-2019, 02:26 PM   #9
DouglasReid's Avatar
If they aer plugged open them up with a small drill so it will drain and keep the bugs from entering or building a nest that will plug it.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
drain, fridge
