Old 08-24-2015, 07:39 PM   #11
Originally Posted by shughey00 View Post
My mother just put one in hers and it really dropped the temps. We may add one to ours. She is in the desert Southwest and had a problem keeping the temp inside below 50...now its just under 40 so...it works.
i think she bought this one off of ebay but not saying other designs are or are not better. I have looked at a bunch and they are all pretty similar. i jst like this one as it was fused and has a switch. Dometic Refrigerator Deluxe Fan to Increase Cooling Inside with Metal Grill | eBay
I purchased this fan and did NOT notice any difference I temperature!
l001952119 is offline   Reply With Quote
Old 08-24-2015, 07:42 PM   #12
Flybob's Avatar
I replaced the fridge bulb with a FFF LED replacement. Nicer light and compensates for the additional current the fan draws.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-26-2015, 06:44 PM   #13
R3Jones's Avatar
Fridge fan
Purchased and installed (2) Corsair 140mm quiet fans and a hand/off/auto (HOA) switch. I removed the existing fan and installed the switch on the 12volt supply. Also I wired in the existing thermal switch to the "auto" side of the switch and a direct wire for the "hand" side of the switch.
The fans are much quieter than the existing and move more air. I haven't had time to check the cool down timeframe but the freezer was noticeably cold in less than 30 minutes. I will post a more thorough follow up when I get a chance to test it.
Name:	ImageUploadedByForest River Forums1440632641.729752.jpg
ID:	87002Click image for larger version
Name:	ImageUploadedByForest River Forums1440632663.175735.jpg
ID:	87003Click image for larger version
Name:	ImageUploadedByForest River Forums1440632679.392220.jpg
ID:	87004Click image for larger version
Name:	ImageUploadedByForest River Forums1440632691.363225.jpg
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 08-26-2015, 07:08 PM   #14
Fans work great if positioned just above the burner and blow across the entire back of the refrigerator.
Old 08-26-2015, 07:13 PM   #15
R3Jones's Avatar
Ok good to know. I left enough slack in the wiring to play with the position. I've installed the replacement fans in the general vicinity of the existing fan location but I'm not sure it was installed in the best location.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
fan, fridge
