Old 04-21-2012, 07:08 PM   #1
Fridge Fan is loud
I have a 2012 xlr 35x12 and when the refridge fan kicks on, it seems to have a pretty loud whine. Is that normal?
cpope84 is offline   Reply With Quote
Old 04-21-2012, 09:47 PM   #2
Seems to be a problem. As a tech, I go to the local computer store and buy a 12 volt computer cooling fan, less than $20, and replace them. Customer service rather than wait on factory to ship another junk one.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-21-2012, 09:50 PM   #3
Will do! Thanks
Old 04-24-2012, 01:14 AM   #4
Loud Fan Solution
Like others, I couldn't live with the cheap muffin fan on the back of the Dometic DM2652 in my Sunseeker cycling on and off. I sourced a couple of 120mm computer 12V fans with built-in thermostatic control from my local computer store (Gelid Silent 12 TC). These fans are bigger than the original 90mm fan and run at a variable speed depending on temp (from 750RPM at 22C to 1500RPM at 42C).
After pulling the fridge, I removed the single 80mm fan and the thermal switch that was clipped to the heat exchanger tube. Just for fun I hooked the new and old fans up to a 12V battery. The new fans were virtually inaudible compared to the original!
I used 4 small angle brackets, screws and a bit of construction adhesive to attach the new fans to the back of the fridge. I also attached the thermal sensors for the fans to the same spot that the original sensor was (pics 1 & 2). Power is still supplied via the same red wire with the inline fuse but I added a shutoff switch in case I really need to conserve power (pic 3).
Now instead of the noisy fan cycling on and off at about a 1 minute interval keeping me awake at night, I have the continuous, but much quieter hum of the 2 variable speed fans. Added bonus, the fridge runs colder than before as well!
Hope this helps others get a better night sleep.
Jim G.
Sunseeker 2300
ID:	12677   Click image for larger version
ID:	12678   Click image for larger version
jgrant911 is offline   Reply With Quote
fan
