Old 01-26-2016, 08:27 PM   #1
Fridge flame out when driving
Hello all. This is my first post. I have a 2015 FR Vibe 268RKS. It has the kitchen in the rear (RKS stand for rear kitchen slide out is what I am told). When we drive the fridge propane flame goes out and when we arrive the check light is on. All works fine when parked. The RV dealer says it is because the exhaust vent on the roof is oriented side to side (rectangular shaped exhaust vent is parallel with the bumber) vs all other kitchens have the vent that is parallel with the length of the RV. They say this orientation allows the wind to be forced down when driving. I temporarily solved it by using duct tape to tape off the roof exhaust vent louver that faces forward and the opening under the exhaust (roof to bottom of vent). This solved the issue. Does anyone know of a devise or something that can be purchased to divert the wind? I am fearful that having one entire side of the vent blocked may cause the CO2 to not properly vent when parked and the wind is coming from the back side. Anyone else have this issue ? RV dealer said I could craft a metal wind block / diverter and mount it in front of vent but I really do not want to drill holes in the roof
I would appreciate any advice
DennisDean2 is offline   Reply With Quote
Old 02-05-2016, 11:38 PM   #2
Wingdreamer's Avatar
Hi, we'll welcome to the forum. I have a 268rks as well. I have towed several times with the fridge running and had no issue. Is this a one time thing or have you towed several times and had the fridge goes out?
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 02-06-2016, 08:21 AM   #3
DennisDean's Avatar
Has happened multiple times. Have taken it out a half dozen times and occurred on every trip. Stopped after I covered vent with duct tape on the front. But also had the CO2 alarm go off one time while parked so I have been concerned it was related to one side of the exhaust vent blocked. I took it to the RV dealer last year while under warranty and said everything looked and worked good. He said they have had this issue before with the rear kitchens but I have not seen any posts or anything else on line. I thought maybe everyone else had this issue. Good to hear yours is doing well
DennisDean is offline   Reply With Quote
Old 02-06-2016, 09:00 AM   #4
It looks like the design is perhaps somewhat marginal. Not only is the roof vent positioned across the TT which pretty much gets draft forced in, but the reefer intake is located on the rear, which is a known low pressure area when towing. You could try taping one of the openings in the reefer intake grill, at least it is far easier to reach.
You could also fabricate a baffle (just an L shaped piece of metal or plastic and stick it to the roof with dicor, RTV or 3M tape...no need for screws. I would put it maybe 3 inches forward of the roof vent and make it 3 or 4 inches high. The vent does not expect to be force fed with 55 MPH winds so it would have no effect when parked.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-06-2016, 09:08 AM   #5
Thumbs up
Good idea to just use Dicor and not screws. I will try that. Thanks for the advice
Old 02-06-2016, 10:20 AM   #6
Usually Confused Member
emm-dee's Avatar
The solution posted may work but I believe you should do some testing first. The flame is going away due to either vacuum or pressure. Since we don't know which then some experimenting is needed.
If the problem is pressure, placing "diverter" described by ScottBrownstein in front of the intake/exhaust would create a vacuum between it and the vent. If the flame stays on then you have found the problem. If it still goes out then move the diverter to different positions ranging from the 130 to 210 degree position behind the vent. That will create turbulence at the vent which would result in the vacuum be eliminated. I'm pretty sure one of those solutions should fix the problem.
Either way, you will be moving the diverter maybe several times so I'd recommend holding it in place with some Gorilla tape. Then, when you have definitely solved the problem make the solution permanent by using Dicor or something similar. Gorilla tape is serious stuff. I've never put tape on a trailer roof so someone else will have to advise if this is a good idea or it might damage the roof.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 02-06-2016, 10:48 AM   #7
Left Coast
Why not attach the baffle to the vent cover and leave the roof alone......
Old 02-06-2016, 10:59 AM   #8
If you attach the baffle to the vent cover it will reduce draft when standing still. Might work but not worth the risk.
As far as testing...good idea. I am sure that duct tape will work equally well while you figure out where it is best positioned. I would vote for pressure in front of the vent.
Dicor is a relatively permanent solution and duct tape or something else is a good way to verify things before going permanent.
2015 335DS
Old 02-06-2016, 11:04 AM   #9
Canadiancrew's Avatar
Sounds like a design issue. I would worry that if is drafting air when driving it would also be subject to getting wet in there while driving in a rain storm.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 02-06-2016, 12:09 PM   #10
Left Coast
? The baffle, if needed, can be configured to any distance away by how big the material is.....so what difference if it's attached to vent cover or glued to roof..........
fridge
