Old 09-15-2013, 09:23 PM   #1
SnoGhost's Avatar
Fridge Gets Too Cold.
I guess it's better than not getting cold enough but on our first trip with our 2004 Wildwood the Fridge got so cold after 2 days that everything in the fridge was frozen. Only running on propane. Fired it up at home on ac power the day before we left then ran it on propane while we drove 2.5 hours to the campground. Also on the 2nd day the check light came on(?) Dometic Americana ...not sure of the unit model # but it has the separate fridge and freezer. Any ideas? Thanks in advance...
SnoGhost is offline   Reply With Quote
Old 09-16-2013, 01:04 AM   #2
typically there is a small sensing bulb attached to one of the fins on the back of the fridge that needs to be moved down. I also had to move the bulb down inside the clip to get mine to the right temperature
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 09-16-2013, 09:34 AM   #3
SnoGhost's Avatar
Thanks Ditchooker...I'll check that out. I know that there is wire with the temp sensor at the end laying in the middle rack. Could that be it?
Old 09-16-2013, 09:53 AM   #4
That sounds like the sensor. It should have a clip that attaches to the cooling fins. I would start off by placing it near the center of a fin vertically. Adjust up or down for proper temp.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 09-16-2013, 09:59 AM   #5
Batts-toy's Avatar
The clip goes on the far right side fin with a sticker next to it for instructions., I just slid mine up to get mine a little cooler.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 09-16-2013, 10:36 AM   #6
SnoGhost's Avatar
Thanks guys for the info. This is a photo of the sensor wire and the what I assume is the clip which should hold the sensor wire up against the cooling fins.(?) ALSO: while I'm at it, what is the "Climate Control" switch inside the freezer door for?
[/URL][/IMG]
Old 09-16-2013, 10:46 AM   #7
That seems to have come loose from the fins ....
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 09-16-2013, 11:09 AM   #8
SnoGhost's Avatar
I guess I should add there is no temp adjustment on this fridge. It is meant to operate at a "Factory Preset Temp".
Old 09-16-2013, 01:23 PM   #9
That sensor is the temperature adjustment, I guess you figured that out already. It is supposed to be on the rightmost fin and you slide it up or down that fin to adjust the cooling. At first I also thouggt there was no temperature adjustment as one looks for a regular know, slider etc
Old 09-16-2013, 02:57 PM   #10
Batts-toy's Avatar
Mine is a 2013 model and does not have a climate control switch in the freezer, you must have a different model than mine also the plastic piece in your photo appears to be longer than mine. Is there a sticker on the wall (inside) next to the fins that shows 'colder - warmer"? If not my guess would be attach the sensor with the plastic piece on the fin and do your 'climate control switch to attain the results you want again just guessing at this point.
fridge
