Old 07-17-2016, 04:43 PM   #11
Flybob's Avatar
That is the sensor. It should clip onto the plastic slider. See photo.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-17-2016, 05:45 PM   #12
That's it. It slips in a slot on back of the plastic.
CedarCreekWoody is offline   Reply With Quote
Old 07-17-2016, 07:50 PM   #13
Thanks everyone that was it. The thing is it was never on that plastic slip and fridge worked fine hmm
2016 mini lite 2306
2012 Chevy traverse
Locchamp is offline   Reply With Quote
Old 07-18-2016, 01:09 PM   #14
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Locchamp,,,,,if that thermistor isn't attached to the fins,,,,it'll make your fridge much colder since it's sensing ambient air instead of the fin temperature. You might have a different problem. Is your refrigerator in a slide-out? And if so, I'll point you to another problem you might have.
Grampa Jim is offline   Reply With Quote
Old 07-18-2016, 04:30 PM   #15
satdog01's Avatar
Gosh I love this forem! I have a 2017 Flagstaff okbs that I picked three weeks ago. Having same issue with refrig. Found the thermistor on the top shelf with ice all over it. Unplugged refrig, got rid of ice, attached thermistor to plastic piece and placed both back on fin. Refrig runs all time, temp at 48 degrees after three days. Gramdpa am interested in other idea you might have, refrig is on third slide out. Dealer is 120 miles away and not much help on phone. Leavin the tt with him is not am option at this time. Goshen is not far away!
Marriot2 on Wheels 2017 Flagstaff Classic 832 OKBS
2013 GMC Denali 6.6L 2500 HD DMAX w\Alison Trans
Pepper Pomeranian rescue 121 days as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
... 2014 = 39, 2015 = 52, 2016 = 77, 2017 = 11
Retired :
satdog01 is online now   Reply With Quote
Old 07-18-2016, 05:16 PM   #16
If your fridge is in a slide-out, venting is all together different than the other way. If your fridge is not in a slide,,,,,the condenser venting outside exits through the roof which is much more efficient. If it's in a slide....the condenser venting outside is "in" at the bottom and "out" at the top......not the roof, but the top of the side directly above the inlet which looks the same. If your fridge is running, you SHOULD hear the fan humming outside,,,,and actually even on the inside. If the fan is not running,,,,,the venting outside is too hot and the fridge will not cool down, and that is your problem. Is the fan outside running? I added another fan to mine so they're in tandom to overcome the ambient heat here in central Texas. Right now it's 93 outside and running full time,,,,,but my freezer stays between 0 and 5 degrees and the fridge is cold enough to have ice crystals in my water bottle sometimes. I don't like the fridges being in slides,,,,,that creates major problems,,,,and I probably won't get another rv with a fridge in a slide.
cooling, fridge
