Old 08-14-2013, 05:53 PM   #1
Captain Skippy's Avatar
Fridge NOT making any noise
New camper and turned on the Dometic fridge for the first time today. Lights work but can't hear anything running. I realize it takes some time to cool down but shouldn't I hear it running? It is switched to auto but is plugged into a 30amp receptacle. I had an electrician wire it specifically for the camper. AC was on and it ran fine but I cut it off since it really wasn't hot enough outside.
Somewhere in Sunny South Carolina.
Maybe...
Captain Skippy is offline   Reply With Quote
Old 08-14-2013, 06:06 PM   #2
Nope. There's no compressor. It will be silent.
Put your hand on the freezer wall. It should be cold soon.
Old 08-14-2013, 06:08 PM   #3
TURBS's Avatar
Most likely you won't hear a thing unless it has air flow fans.
There not like a normal fridge with a compresser.
Fridge should be quiet as a mouse when running.
12 hours minimum cool down period.
Turbs
Old 08-14-2013, 06:16 PM   #4
Well I feel like a dummy. It's been on about two hours and I think I notice a difference. I slid the control to the coldest setting. I'll check it in the AM. I remember the dealer saying to turn it on the day before you want to use it.
Thanks guys.
Maybe...
Old 08-14-2013, 06:44 PM   #5
Oakman's Avatar
Most RV refrigerators cool down faster when using propane instead of electricity.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 08-14-2013, 08:22 PM   #6
That's good to know. Thanks.
Maybe...
Old 08-14-2013, 09:15 PM   #7
Brother Les's Avatar
Hello Captain, my friend, I have been a 'camper' for over 45 years. For you (any newby) there are many 'small' things to learn that those who have been doing this for a while really never think about and completely forget to think about. I had to stop and think if my fridge made any noise? No noise...but it works...
when you said.
what do you mean by this? I thought that you had a new camper and it would seem that it would have came with a duel fuel (propane/electric) fridge. Did you add a second fridge that is only electric?
These small camper fridges do take 4-6 hours to cool down. Why does it take so long? Because most of the time it is empty when 'we' turn them on to cool them down. The cooling system is small, but works really well for what it is asked to do. A 'full' fridge (just like at home) will stay cold easier and faster if it is full. A day before we 'stock' the camper I will connect the batts (I disconnect them so that will not run them down from parasite usage from the safety monitors) plug the camper in and then turn the fridge on. I like to have the fridge 'on' when I am running down the road, so when we are ready to roll. I will unplug it and open the primary propane tank. The gas will take a while to force its' way to the fridge, so I turn on a stove burning to get the gas back to the fridge faster. Air will come out of the burner and I hit it with a lighter every few seconds to see if it will start. All of this time I am hearing the fridge lighter clicking away trying to ignite the propane that is not there. After several trys the fridge will default off and ask me to 'check' it. I will reset the fridge button after I get propane to the stove. Once the propane is lit on the fridge (you should hear it ignite) it will be fine as you go down the road on your trip.
Happy trails and enjoy your new camper. It may seem like a lot of work sometimes and it is, but the rewards are worth it all.
Blessings
Brother Les
Old 08-14-2013, 09:38 PM   #8
Our fridge doesn't make a sound and takes a few hours to cool down but works great...beer stays cold...:-)
_______________________________________________
Tim & Jenn
2009 Forest River Grey Wolf 235 5er
2003 F-350 Superduty 6.0 l Diesel
DSP 17K
aiscpl6 is offline   Reply With Quote
Old 08-14-2013, 09:44 PM   #9
I really didn't make that clear. The dealer I bought the camper from said I could plug it into a regular household plug with a 30amp to 110v dog bone but not to run the AC on 110. I had an electrician run a separate 30 amp line from my meter base to plug the camper in. Now I can run everything while getting ready to head out and I can camp out in the yard with the grand kids.
Maybe...
Old 08-14-2013, 09:50 PM   #10
By the way, I do have the outside kitchen option with a second fridge. But it only runs off 110 electricity. It was plugged into a receptacle behind it and the on/off control was on the back of the fridge, which was bolted down. Really dumb. You couldn't reach the control. So I unbolted everything and plugged a power strip with an on/off switch. Now I can keep it off until I'm actually ready to use it and have a few extra receptacles to boot.
Maybe...
fridge
