Old 08-08-2013, 06:21 PM   #11
Patrickdana's Avatar
Originally Posted by BarryD0706 View Post
Do you have the (noisy) fans on the back of the fridge (outside)? Do they run normally when the temp is 50?
No fans visible. Refrigerator is not in a slide.
For God hath not given us the spirit of fear; but of power, and of love, and of a sound mind. 2Timothy 1:7
Patrickdana is offline   Reply With Quote
Old 08-11-2013, 07:23 PM   #12
Is your fridge mounted in a slide-out? If so, it should already have some fans outside in the back of it to move air over the condenser. These fans are thermostatically controlled. If they aren't running that would cause this problem. (If your fridge isn't in a slide-out, it may well not have the fans.)
Have you learned anything more about your refrigerator? Out 1350 does the same thing.
Old 08-11-2013, 07:36 PM   #13
should be a frigidaire residential in the 36RE and would not matter what outside temps are would still keep things cold. used mine all last summer here in Florida, never had a problem
bob34787 is offline   Reply With Quote
Old 08-11-2013, 07:43 PM   #14
Originally Posted by GRHooper View Post
I left my 2011 Cedar Creek 36RE for about 10 days at the dealership to have some work done. It has been very hot and humid here with temps at or above 100 for several days. Now I cannot get my fridge to work properly; it shows 54 degrees, the freezer reads about 32 degrees. What else should I do to try to get it going before calling the service man? It is a Dometic RM1350. Thanks!
Has your 1350 refrigerator been repaired. Have you discovered the problem. Mine does the same after about 9 months of proper operation.
Old 08-11-2013, 07:47 PM   #15
Do you know what model residential refrigerator will fit in place of the Dometic 1350?
Old 08-12-2013, 07:58 PM   #16
Medic44's Avatar
Well our 1350 has the same problem, one day its 50 degrees and the next day its 36 it doesn't matter if its 70 or 90 out side. I have checked mine and we have two fans on the top vent out side, I have checked the reset button on the unit also. Our unit is so level its not funny. I have called to shop and they said "bring it in at the end of the month" REALLY, Hope some one finds a answer to this problem and soon.
Tom & Shawna, (Joey, Chelsea)
2011 Crusader 320RLT
Medic44 is offline   Reply With Quote
Old 08-12-2013, 08:34 PM   #17
Do you hear the fans running sometimes? They are noisy so you should be hearing them cycle on and off.
Old 08-13-2013, 10:33 AM   #18
Medic44's Avatar
BarryDo706, Yes I hear them running, I was thinking maybe they went out? but NO. even tried a third fan and no improvement. <;-(
Old 08-15-2013, 03:24 PM   #19
Update on my RM1350. Did a bypass test (24 hours with power directly applied to heating elements). Temp did not go below 40 with outside temp at 50. Measured the resistance of the heating elements (34 ohms). Measured current draw of heating elements (3.48 amps). Took unit to warranty repair facility where my tests were repeated. Results is defective cooling unit. Replacement unit on order. Will update after new cooling unit is installed.
Old 08-20-2013, 07:15 PM   #20
My DM2652 Fridge had a defective cooling unit also. When they emptied the coolant out of the cooler it was black..was suppose to be yellow. Not a happy camper seeing we just bought the 2010 Sunseeker this past April.
SmileyJoJo is offline   Reply With Quote
fridge
