Old 08-20-2013, 07:32 PM   #21
VinceU's Avatar
Originally Posted by Medic44 View Post
Well our 1350 has the same problem, one day its 50 degrees and the next day its 36 it doesn't matter if its 70 or 90 out side. I have checked mine and we have two fans on the top vent out side, I have checked the reset button on the unit also. Our unit is so level its not funny. I have called to shop and they said "bring it in at the end of the month" REALLY, Hope some one finds a answer to this problem and soon.
Keep in mind the 1350 goes through a auto defrost cycle every other day about the same time. The sensor is close to the cooling coil (fridge) and will pick up 10 degrees or more for a period of time. Perhaps you are seeing this same time every other day?
Old 08-20-2013, 08:24 PM   #22
Patrickdana's Avatar
Bypass mode rules out everything but cooling unit.
For God hath not given us the spirit of fear; but of power, and of love, and of a sound mind. 2Timothy 1:7
Patrickdana is offline   Reply With Quote
Old 08-20-2013, 08:27 PM   #23
VinceU's Avatar
Agreed, was posting for others, yours is shot, any ammonia scents in back?
Old 08-20-2013, 08:30 PM   #24
Not on this one but have observed rupture of tubes on other units.
Old 08-20-2013, 08:38 PM   #25
VinceU's Avatar
One more thought before off to the shop. Some have found a cure by vibrating the sinuous coils in the back of the fridge. Often there is a temporary blockage with rust and other contaminants. These normally circulate but can collect and cause a pressure reducing blockage. Use a heavy dowel or 2x2 and vibrate the tubes. Improvement if it works will be soon after. Believe I saw in a Dometic trouble shooting guide.
Old 08-20-2013, 08:49 PM   #26
Sounds reasonable. If the unit wasn't under warranty better believe I would try it.
Old 08-24-2013, 07:21 AM   #27
New cooling installed temp control set on 3 refrigerator is at 35 freezer at 0.
Old 08-24-2013, 07:36 AM   #28
VinceU's Avatar
Great news!
Old 08-27-2013, 08:55 PM   #29
Medic44's Avatar
VinceU: Sounds good but this is every day, All day, from the time we get up to the time we good to bed. still open for ideas???
Tom & Shawna, (Joey, Chelsea)
2011 Crusader 320RLT
Medic44 is offline   Reply With Quote
Old 08-28-2013, 10:37 AM   #30
VinceU's Avatar
A few more ideas:
Flap hanging on left door, must shut every time.
Auto defrost every other day
Electronic circuit board could be faulty, contols temp.
Refrig and freezer must be manually defrosted 1-2 weeks-
Condener air flow not always issue. Fitted fans should be enough.
If I add more than a six pack, the temp rises like a ballon.....
fridge
