08-20-2013, 07:32 PM
#21
Originally Posted by Medic44
Well our 1350 has the same problem, one day its 50 degrees and the next day its 36 it doesn't matter if its 70 or 90 out side. I have checked mine and we have two fans on the top vent out side, I have checked the reset button on the unit also. Our unit is so level its not funny. I have called to shop and they said "bring it in at the end of the month" REALLY, Hope some one finds a answer to this problem and soon.
Keep in mind the 1350 goes through a auto defrost cycle every other day about the same time. The sensor is close to the cooling coil (fridge) and will pick up 10 degrees or more for a period of time. Perhaps you are seeing this same time every other day?
08-20-2013, 08:24 PM
#22
Bypass mode rules out everything but cooling unit.
For God hath not given us the spirit of fear; but of power, and of love, and of a sound mind. 2Timothy 1:7
08-20-2013, 08:27 PM
#23
Agreed, was posting for others, yours is shot, any ammonia scents in back?
08-20-2013, 08:30 PM
#24
Not on this one but have observed rupture of tubes on other units.
08-20-2013, 08:38 PM
#25
One more thought before off to the shop. Some have found a cure by vibrating the sinuous coils in the back of the fridge. Often there is a temporary blockage with rust and other contaminants. These normally circulate but can collect and cause a pressure reducing blockage. Use a heavy dowel or 2x2 and vibrate the tubes. Improvement if it works will be soon after. Believe I saw in a Dometic trouble shooting guide.
08-20-2013, 08:49 PM
#26
Sounds reasonable. If the unit wasn't under warranty better believe I would try it.
08-24-2013, 07:21 AM
#27
New cooling installed temp control set on 3 refrigerator is at 35 freezer at 0.
08-24-2013, 07:36 AM
#28
Great news!
08-27-2013, 08:55 PM
#29
VinceU: Sounds good but this is every day, All day, from the time we get up to the time we good to bed. still open for ideas???
Tom & Shawna, (Joey, Chelsea)
2011 Crusader 320RLT
08-28-2013, 10:37 AM
#30
A few more ideas:
Flap hanging on left door, must shut every time.
Auto defrost every other day
Electronic circuit board could be faulty, contols temp.
Refrig and freezer must be manually defrosted 1-2 weeks-
Condener air flow not always issue. Fitted fans should be enough.
If I add more than a six pack, the temp rises like a ballon.....
09-01-2013, 06:20 PM
#31
VinceU: Thanks for more thoughts anything helps
*1 - Always close the left side flap
*2 - hope this is happening
*3 - Circuit Board???? Hmm ???
*4 - defrosted 1-2 wks went all last summer from April - Nov and didn't do this and no problems with unit???
*5 - two fans on upper unit in back blowing on unit.
got up three days ago and temp was 36 well was long after that went to 54 and yep you got it been there ever since <;-( unit does not have much in it, we have set up a small unit out side in the 100 degree heat and its keeping everything cold. sounds like a Long Trip to Dealer again.
09-01-2013, 09:28 PM
#32
If I was a betting guy and had the choice of what to renew, I'd pick the PCB which is falsely reading the box is down to temp. That's probably a couple hundred or less. Cooling unit would come next like Patrickdana in this same thread, but that's a couple of thousand (maybe 3500). Is this under warranty? The box retails for 7K, worth a trip to the dealer! Its good to troubleshoot like you have, a Dometic rep would know much better what to change.
09-02-2013, 12:27 AM
#33
I am having the same issue with my fridge. The fridge is not cooling down and the fans has been running all day.
2014 stealth 2714
09-05-2013, 06:04 PM
#34
Well heck the fridge has been holding at 34 - 35 for the last two days. and I don't know why ???? Hmmm ???? Really ???? We didn't do anything lol
09-05-2013, 06:08 PM
#35
I took mine into the dealer to check it out
2014 stealth 2714
09-05-2013, 07:07 PM
#36
Just had to get my Dometic cooling unit on the back of fridge replaced. Coils were so corroded ammonia could not circulate even after having it flushed 3 times. Price wasn't bad for just the coil unit on the back compared to a new fridge. I always make sure the motorhome is level as this is an important part for the fridge to work better. Need to say I wasn't impressed seeing just bought Motorhome 6 months ago and it is a 2011.
09-05-2013, 07:18 PM
#37
HA! I wouldn't store your steak and lobster dinner in that box!
#38
Mine is a 2014 so hopefully everything will be fine. It was hot out that day, but the fridge is in the middle of my Tt
2014 stealth 2714
