Old 10-18-2012, 04:26 AM   #1
Tilly's Avatar
Fridge on the fritz any suggestions?
Two days ago my fridge would not light. With the cover off I could see the blue flame sparking but it would not stay light. It makes a puff sound like its trying. All other propane appliances work OK. I finally found a forest river dealer wou would look at it since most don't seem to handle warranty unless they sold it. Myers RV center in Albuquerque was very friendly and said they fixed it but alas 24 hours later it won't work again. Now I can hear it burning but the igniter keeps sparking. Then it goes out and puffs for awhile then catches on but keeps sparking. It cycles like this for a few min the check light goes on and it gives up.
Any suggestions? I'm giving away all my perishibles since I'm 100 miles from a dealer and have an appointment tomorrow.
Thanks in advance
Malinda
Ps I am now in Sedona az. Any recommended dealers in Phoenix?
Tilly is offline   Reply With Quote
Old 10-18-2012, 07:42 AM   #2
TURBS's Avatar
Sound like the gas valve isn't holding?
Make and model of fridge would help.
Depending on the fridge Lou may have a trouble shooting file for it.
Turbs
Old 10-18-2012, 08:32 AM   #3
Tilly's Avatar
It's a dometic. Dmx2652rbx. It can run on gas or 110. I'm not hooked up and not allowed generators where I am now
2013 Sunseeker 2300
Chassis: Chevy 4500
Toad: 2004 Shadow Aero
"On the Road" since 8/8/12
Every Day's a New Adventure!
Old 10-18-2012, 08:48 AM   #4
Road-King's Avatar
I don't have a Dometic, but to me it sounds like the thermocouple is not doing it's job. If the igniter is still trying to light the flame after it is already lit, the thermocouple is not sensing the flame. Just a educated guess....
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-18-2012, 03:52 PM   #5
Tilly's Avatar
That makes sense. It's definitely a sensor issue of some sort. It finally caught and is doing OK for now but not sure how long to trust it. Intermittent issues are a bugger to diagnose.
2013 Sunseeker 2300
Chassis: Chevy 4500
Old 10-18-2012, 05:46 PM   #6
I second the thermal coupler.
2013 Surveyor SP-280 10th Anniversary
2010 Nissan Titan
jeerme is offline   Reply With Quote
Old 10-19-2012, 06:48 AM   #7
Herk7769's Avatar
It could also be bugs have built a nest in your flue pipe.
I am assuming that from the "start - out - start" sputtering, that the gas stays on through the entire cycle.
If so, a spider web in the flue can alter the mixture to above or below its optimum mix for combustion. Too much or too little propane vs the available air (determined by the shutter on the burner pipe) and the propane will not light.
If the flue is obstructed, exhaust gases from the flame have no place to go and will snuff out the flame. Once it clears it could relight and the cycle repeats similar to a pulse jet engine.
Sounds like eventually the heat has burned out the nest/web and it should work ok. If that is the case, I would still have it checked as the flue could still be partially obstructed.
Here are my files on your fridge.
File Type: pdf Fridge Operation and Trouble shooting.pdf (94.4 KB, 28 views)
File Type: pdf DM2652 RV Fridge Installation Manual.pdf (3.05 MB, 30 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-19-2012, 08:19 AM   #8
mine did that on my rockwood travel trailer had to move the sparker so it was close to flame and it work fine ever since
jkklops is offline   Reply With Quote
Old 10-20-2012, 08:02 PM   #9
Tilly's Avatar
I'll look at the sparker and see if that's odd. With some I the roads I've been in it could have loosened. It's been running fine the last couple of days. Thanks to everyone for the replies.
2013 Sunseeker 2300
Chassis: Chevy 4500
