Old 07-15-2013, 01:06 PM   #1
Fridge problem
I'm having a problem when I use propane to run the fridge.
When I first switch it to propane you can hear it light and hear the burner. But after some time (time varies) it starts to click. It will click for about 10 seconds or so. It seems to me that it doesn't recognize that it is already lit and is trying to ignite the burner again. After it fails, (since it's already burning) it shuts down completely. Has anyone else had this problem?
cdbus is offline   Reply With Quote
Old 07-15-2013, 01:12 PM   #2
Herk7769's Avatar
How is your propane pressure? Does your range flicker?
HAM CALLSIGN - KC3FFW
Old 07-15-2013, 01:18 PM   #3
I have never had problems with the range, oven, or hot water heater. I didn't know if the jet could be clogged or if there was some sensor on the fridge that needed to be changed.
Old 07-15-2013, 06:32 PM   #4
Are you sure you have propane?
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
