Old 08-08-2016, 09:49 PM   #21
^ x2... pics would be great!
Thanks for the creative solution.
2015 Flagstaff Hard Side T12RBTH (aFrame)
2014 Toyota Sequoia iForce V8 4x4
"Walk Back"
nstearns is offline   Reply With Quote
Old 08-08-2016, 11:12 PM   #22
Another proven solution: Buy a spare stock "jet". Solder it closed with silver solder and redrill the jet one or two sizes smaller than stock size. Problem solved!
Skyliner is online now   Reply With Quote
Old 08-08-2016, 11:47 PM   #23
HONDAMAN174's Avatar
When camping one trip in my pop up at 8500 ft, I had to open the water heater and outside fridge vent to get additional air. Now with my current unit we are camping during the summer at 9000 ft. But I don't have any issues with my new unit. The difference/ reason is that I installed 3 5 inch computer fans to increase airflow to help the fridge get cooler cause I live in such a hot climate. I have two up top sucking and one in the lower door pushing air in. After reading your troubles, I am thinking that more airflow could be a solution.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 08-09-2016, 09:47 AM   #24
Thanks for all these suggestions! We have an appt to take our camper in next week for this & another issue. We'll see what they can do - I'm going to show them these suggestions even though I know they likely won't do them. I'll let you know! We head back up to a higher elevation a couple weeks later.
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
Old 08-09-2016, 05:34 PM   #25
TsnTexas's Avatar
More ideas! Phil, some pics would be great so we could see your handiwork. I too am surprised by the open gap in that system.
TsnTexas is offline   Reply With Quote
Old 08-10-2016, 06:54 AM   #26
I'm at the FR rally in Goshen right now, site 429. I'll need to disassemble the burner area to take pics and I'll try to get to it today or tomorrow.
Phil
pmsherman is offline   Reply With Quote
Old 08-16-2016, 01:38 PM   #27
TsnTexas's Avatar
Here's a thought: assuming the regulator is adjustable, would lowering the pressure (water column) a small amount result in a more efficient flame at altitude?
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 08-16-2016, 02:02 PM   #28
Propane is liquid gas and with the colder temperatures and thinner air, the liquid can only
be converted to a gaseous state at a certain rate. If you have a look at your propane tank once your fridge quits, I would wager that the tank itself is iced up and therefore you are getting little to no gas flow.
Happens to me all the time here in the winter when I am using my propane turbo heater in my pole barn. A 20 pound tank will only provide "x" cu. ft of propane gas @70 degrees and sea level. Dropping temperature and increasing the elevation is going to that reduce cu.ft. with the colder it gets and the higher you go, the less available cu/ft/min
ShermanD is offline   Reply With Quote
Old 08-16-2016, 05:03 PM   #29
We have good friends who have a Windjammer that has, I believe, the same fridge. They go to some of the same places we've gone, both with mid-summer heat & freezing night temps in the Fall, & their fridge has never failed them.
We have our appt tomorrow drop off our TT to get it checked out. I'll let you know when we get it back - they are saying about 7-10 days. Keeping our fingers crossed for a fix of some sort.
2016 Rockwood 2504S
Old 08-16-2016, 05:35 PM   #30
TsnTexas's Avatar
Thanks, my sister in law is camping at 9500 ft. for three days now with their Norcold fridge (also on propane) and haven't had so much as a hiccup. In fact they were quite surprised to hear that we had problems. Our Dometic is brand new and theirs is probably 5 years old. Go figure.
2016 Rockwood 2504s
2016 Chevy 2500HD
fridge
