Old 09-01-2016, 05:26 PM   #31
OK, add me to the list. North rim Grand Canyon, 8200 ft., Dometic RV frig 1 1/2 years old. Every morning awoke to find the check light on. After the day warmed up a tad, worked ok. Early morning, could hear click click click, ignite for a sec, go out, on and off. Sometimes stayed lit, other times didn't. Flame was loud when on. No AC available when dry camping. Let's stick to the propane for now.
I've read a lot on this forum and other sources. Here are some comments and questions:
1. Some people say to get a smaller orifice as the problem is too rich a mixture in this lower oxygen environment, however, no smaller orifice available from the company. I saw the Servel Dometic RGE400 High Altitude Jet online. https://www.thenaturalhome.com/gasappliances.htm
Any experience with this?
2. Others on this thread have tried creating a partial metal tube to help keep the propane jet flowing centered toward the burner as he says the lower air pressure doesn't keep the propane jet contained. Seems to me that would enrichen the mixture even more when we want more oxygen (lean)?
3. Others recommend increasing the regulator from 11" to 13" water. Wouldn't that also enrichen the mixture?
4. Others recommend opening up the housing to allow more air in, while some block airflow with a chair to keep the flame from being blown out.
YOW! I need an easy, occasional solution for occasion trips to altitude - and please don't say "ice chest." This can't be that hard.
Thanks,
Russ
Russmd is offline   Reply With Quote
Old 09-02-2016, 11:37 AM   #32
northstar1960's Avatar
Thanks,
Russ
. did you clean the burner tube [boiler] do you know if your flame sensor is clean ? if so and still issues then allowing more air in or less gas out will help . do not increase WC . on my old unit allowing more air in helped .
But by all means get a high alt orifice if available that's the only real solution
northstar1960 is offline   Reply With Quote
Old 09-02-2016, 12:12 PM   #33
I haven't cleaned anything yet as it's so new, but I will. Where is the flame sensor? I haven't heard of that before. The unit works perfectly at lower altitudes.
Most everybody says there's no smaller orifice available, but I saw the one mentioned earlier. Does anyone have any experience with it?
Does that "metal tube" idea sound plausible to others. It's further back in this thread.
Thanks.
Old 09-02-2016, 06:21 PM   #34
Russ - We live in Colorado at an elevation of 5600'. Our fridge works fine here but won't keep running on propane when we go to the mtns. - especially at night when it's already getting cold. Our new 2504s is in the shop now to check that out as well as a couple other warranty issues. When we dropped it off, they told us there is a different orifice that works at 10,000' & above - but it's not recommended for lower elevations. They are checking out the mother board as well as other things - hopefully we'll get an answer I can pass along. It's taking longer than expected to get it back because they had a huge hail storm that damaged 35 units - supposedly, not ours.
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
Old 09-02-2016, 08:50 PM   #35
Thanks. I'd be very interested to hear about the substitute orifice. From what I understand, they're easy to swap out when one goes to a higher or lower elevation. That would be fine with me. Thanks.
Old 09-08-2016, 12:03 PM   #36
Well, we got a call back from the dealer last night saying our camper is ready. They blew out sawdust & debris from around the orifice $ flue & are calling it good. Said it ran fine - of course it did, the dealer is at about 5,400'. $55 charge to us to remove what was left behind from the build. Oh well, it is what it is. This service mgr knew nothing of the high altitude orifice and really didn't seem to care. I'm not a real happy camper right now but we're taking it up to 8-8,500' in couple weeks & see what happens. Maybe it will work like a dream. If it quits on us again, the next step will be a call to the manufacturer & then possibly trying one of the fixes talked about here. At least they did fix around the slide where you could see daylight at the lower corners when shut. That was under warranty.
2016 Rockwood 2504S
Old 09-08-2016, 01:27 PM   #37
I'll be very interested to hear how it goes after your trip. Thanks.
Old 09-08-2016, 01:59 PM   #38
I'll definitely update you!
2016 Rockwood 2504S
Old 10-03-2016, 12:03 PM   #39
Well, it seems that the dealer blowing out sawdust & debris left behind from the build in the area of the orifice & flue fixed the problem. We spent this past weekend at 9400' and the fridge stayed on the whole time. Frustrating to think the whole problem was caused by debris that should have been cleaned up before it got to us, but the dealer said they did nothing else. As long as that fixes the problem, we won't look into the high altitude orifice. They told us to periodically open the vent on the back of the fridge & blow it out really well. We are expecting our first freeze later this week so it's time to winterize. Will keep fingers crossed for a working fridge next summer!
2016 Rockwood 2504S
Old 10-03-2016, 03:56 PM   #40
TsnTexas's Avatar
Doxies, thanks for following up, although I'm surprised that simply blowing out the debris in the area could do much, I'm willing to give it a try.
TsnTexas is offline   Reply With Quote
fridge
