Old 11-04-2015, 11:42 AM   #1
BuckeyeGal
Fridge Question
Dometic Fridge in our 2012 Sabre 31-CKTS is running at about 33-30 degrees even the temp control was set to the warmest setting. any idea why or what to do about it?
Terry & Carol
2012 Sabre 31-CKTS-6
2003 F-250CC 7.3L Powerstroke
buckeyegal is offline   Reply With Quote
Old 11-04-2015, 11:53 AM   #2
I had the sensor bulb come loose from the plastic slider. I used a little silicone to hold it in place. On mine, the bulb is supposed to be even with the top of the slider. I also use a spring type paper clip to help hold it in place so it does not move while traveling. If this is not your issue, there is a kit, I think it is called the "snip the tip", Dometic Thermistor Repair Kit
Filthy Beast is offline   Reply With Quote
Old 11-08-2015, 09:12 PM   #3
Cajun Style's Avatar
30-33 is a good temp you don't want it any warmer, milk and meat need to be kept cold.
Harry-O
Cajun Style is offline   Reply With Quote
fridge
