i'm not totally sure i understand where the drip is. if it is coming from the filter i'd at least try to reseat the filter, make sure it is making a good seal, and see if that helps. other than that i have no idea.
did you winterize the refrigerator? did you pump antifreeze into it? there are plastic water lines in it. if one of those burst it would have to be replaced. doable, but you have to get to the rear of the refrigerator. no easy in an rv.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
