Old 09-26-2016, 04:13 PM   #1
Decon Blue's Avatar
Question Fridge sweating inside
My fridge in my new 2016 Flyte FQ works fine. Nice and cold, freezer fine too. But I have quite a bit of moisture inside, especially on the outside of the freezer door. Any suggestions??
Retired and loving it. Still looking for that perfect high.
Decon Blue is offline   Reply With Quote
Old 09-26-2016, 04:31 PM   #2
Iwannacamp's Avatar
On regular refrigerators.. sweat around the door usually means air leakage. Do the dollar bill drag test to see if it is loose somewhere around the door. Residential reefers have heaters around the door to help keep it dried up.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Old 09-27-2016, 02:09 PM   #3
Decon Blue's Avatar
Did dollar bill trick, good seal all way around door. Fridge and freezer work real good. Just sweats inside, mostly on outside of freezer door. Anymore suggestions??
Old 09-28-2016, 11:54 AM   #4
Head Rambler
What make and model fridge do you have?
In Fla the humidity has been killer this year. That's contributing to the sweating.
What does this mean? Is the sweating mostly outside the freezer door.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-28-2016, 12:03 PM   #5
Decon Blue's Avatar
It's a Dometic, it means as said that the sweating in mostly on outside of freezer door, but inside fridge itself. I live in Florida, been here little over 10 years now, all other RV's I've had never sweated like this one. Works great, just freezer door always wet on outside of FREEZER door only. It drips inside fridge area off the Freezer door.
Old 09-28-2016, 01:40 PM   #6
Head Rambler
Sounds like maybe it's missing some insulation in the door.
Being that it's a 2016 model, it should still be under warranty. Might want to have the dealer look at it.
Gotta go campin!
Old 09-28-2016, 01:45 PM   #7
X2
Yep, sound like there is no insulation in the door.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is online now   Reply With Quote
Old 09-28-2016, 02:07 PM   #8
We get a fair amount of sweating from the freezer door area with our Dometic when it is humid out. Around here that means late spring to the end of summer. The exterior door seals and freezer door seals are fine on our unit. I think some of it has to do with the small size such that when you open the door the interior air is fully replaced with the humid outside air. A couple of things I do that helps minimize the amount of condensation is to fill the drain hose with water when we arrive at our site and not open the door very often. To this end we only use the fridge for food and keep things like drinks in a cooler. Doing this has also helped keep the coils from icing up quickly on longer trips.
2015 F150 Ecoboost
2014 Palomini 142 CK
keith_h is offline   Reply With Quote
fridge
