Old 06-02-2016, 03:20 PM   #11
BandJCarm's Avatar
That thing drove me insane on our previous camper.
Don't tell DW but I may have bought a fifth wheel just to get a refrigerator with real digital numbers.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-02-2016, 08:03 PM   #12
RailwayRog
I have the same fridge, but I have an additional on and off switch labeled "climate control switch", not sure what the function is for?
2010 Coachmen Prism M240
(2008 Freightliner 3500 chassis)
RailwayRog is offline   Reply With Quote
Old 06-02-2016, 08:11 PM   #13
flymhi's Avatar
Originally Posted by Triple SS View Post
the thermostat thing came out of the sliding plastic. I have tried taping it back in and it did not work. How can I keep it in the sliding plastic which also seems a little loose on the fin
For the loose slide, take it out of the fridge, heat the folded edge with a lighter or torch and squeeze it tighter while it cools. This may take three hands. Duct tape should hold the thermocouple sensor in the holder.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is online now   Reply With Quote
Old 06-02-2016, 09:00 PM   #14
Fulltime family RVer
One of these days, I'm going to install my "snip the tip" refrigerator temperature control. Supposedly they're the bees knees to replace that stupid slider.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 06-03-2016, 06:20 AM   #15
Wolverine 1945's Avatar
We keep thermometers in all our refrigerators,,, I like knowing what they are doing !!!
Wolverine 1945 is online now   Reply With Quote
Old 06-03-2016, 08:43 AM   #16
Filthy Beast's Avatar
I had the RTD come loose in our Dometic DM2652RBX. I contacted Dometic and they told me the position for it, which was level with the top. I used a little RTV to keep it there and one of those spring type paper clip/binder to hold the whole thing where I put it.
Goody Two Shoes and the Filthy Beast
2008 Chevy Silverado 2500HD
Duramax and Allison 6 speed
2012 Wildcat 282RKX
You can't make things idiot proof, you can only make them idiot resistant.
Filthy Beast is offline   Reply With Quote
Old 06-04-2016, 10:58 AM   #17
HarrynSally's Avatar
https://youtu.be/OmzDYZFYmx0 This might answer your question better!
HarrynSally is offline   Reply With Quote
Old 06-04-2016, 11:14 AM   #18
If you don't have a decal to note which way to move the Thermistor, remember the phrase, "Down to Hell" to remember. "Down" is warmer... This has worked for me over the years. You can also have a Dinosaur Electronics brand control board put in the fridge to provide you with more control over temps if needed.
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
lakejumper is offline   Reply With Quote
Old 06-04-2016, 03:17 PM   #19
MNtraveler's Avatar
Fridge too cold, no dial to adjust, only thingy on fin in fridge? How do I ad...
Agreed - one in the refrig and one in the freezer takes all the guess work out of it and let's you adjust the slider to get it right (why they don't use a real thermostat is beyond me!).
These are good and small. I'm not sure why they are listed for $20. I bought several on Amazon for $2 each. They are accurate +/- 2 degrees or so which is adequate for this purpose. If you are compulsive (like someone I know) you can test them against a known good unit such as an infrared thermometer and mark it as +1 or -2 so you will always know.
Cooper-Atkins 330-0-1 Refrigerator/ Freezer Vertical Glass Tube Thermometer https://www.amazon.com/dp/B0041TJCB4..._EzZuxbBXF32T6
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 06-04-2016, 03:18 PM   #20
MNtraveler's Avatar
Or use a Sharpie to write "warmer" and "colder" on the wall. Done.
2016 Forester 2401R
fridge
