Old 06-04-2016, 03:37 PM   #21
Install inside fans to circulate the air, you may want to leave it set where it is.
Old 06-05-2016, 12:27 AM   #22
HarrynSally's Avatar
snip-the-tip.com
Put one in mine, works for me!
HarrynSally is offline   Reply With Quote
Old 06-05-2016, 01:16 AM   #23
Look at this on eBay http://www.ebay.com/itm/390661070734
Great cooling fan for inside !
Old 06-05-2016, 01:21 AM   #24
Look at this on eBay http://www.ebay.com/itm/252386910825
Put this behind the fridge under the coils comes with a switch and temp switch!
Old 06-05-2016, 05:40 AM   #25
geezer with gadgets
757Dave's Avatar
Here's what we use to see the temperature.
Amazon.com: AcuRite 00986 Refrigerator/Freezer Wireless Digital Thermometer: Home & Kitchen
This way we don't have to open the door to see the temperature.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
Days camped 2015: 37; 2016: 66
757Dave is offline   Reply With Quote
Old 06-05-2016, 06:12 AM   #26
Wolverine 1945's Avatar
Originally Posted by MNtraveler View Post
Agreed - one in the refrig and one in the freezer takes all the guess work out of it and let's you adjust the slider to get it right (why they don't use a real thermostat is beyond me!).
These are good and small. I'm not sure why they are listed for $20. I bought several on Amazon for $2 each. They are accurate +/- 2 degrees or so which is adequate for this purpose. If you are compulsive (like someone I know) you can test them against a known good unit such as an infrared thermometer and mark it as +1 or -2 so you will always know.
Cooper-Atkins 330-0-1 Refrigerator/ Freezer Vertical Glass Tube Thermometer https://www.amazon.com/dp/B0041TJCB4..._EzZuxbBXF32T6
Land of 10,000 Lakes
2016 Forester MBS 2401R
I like the Horizontal ones that hang on the door shelf !!!
As you say,,, one in the fridge & one in the freezer !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-05-2016, 02:59 PM   #27
Just back from a week-long camping trip in the new trailer. Have slipped the white plastic slider thing down all the way. It is on the left most fin.
Still pretty chilly in the refrigerator, some food is still freezing. Temperature is 28 or so in the fridge and several degrees below zero in the freezer.
If that does not make it stop freezing food in the fridge, do I move the white thing to another fin?
hbidlack is offline   Reply With Quote
Old 07-05-2016, 11:46 PM   #28
MNtraveler's Avatar
Are you sure the thermistor (the wire portion) is sliding down with the cover? They have a way of coming apart.
I haven't tried it, but someone said if still too cold, move the slider to a more inside fin where it is colder donor will ask for less cooling.
2016 Forester 2401R
MNtraveler is online now   Reply With Quote
Old 07-06-2016, 06:29 AM   #29
Never understand how those things worked ???
But in our old TT it was on the fin to the far right ???
Old 07-07-2016, 07:14 PM   #30
MNtraveler's Avatar
Fridge too cold, no dial to adjust, only thingy on fin in fridge? How do I ad...
Yeah, it's on the far right of ours too. But this one must be on the opposite side. They work by sensing the temperature level. When placed higher where it is warmer, they call for more cooling. When placed lower where it is cooler, they call for cooling less often. It's counterintuitive because "up" is where the cooling fins are. But cold air falls and warm air rises, apparently fast and often enough to make this wonky method work.
2016 Forester 2401R
fridge
