Old 07-07-2015, 07:55 AM   #11
The igniter could be loosing ground, make sure it is tight and grounded.
Old 07-07-2015, 05:05 PM   #12
Mine takes about 6 tries before it will say lit. I just sit and reset it until it stays lit. Lighting a stove burner first helps a lot.
Harkerr is offline   Reply With Quote
Old 07-11-2015, 01:58 AM   #13
Cajun Style's Avatar
You said your plunged into the house is the through the camper or with a bypass regular extension cord?
It will need 12V to operate.
With a Battery or through camper cord.
Cajun Style is offline   Reply With Quote
Old 07-11-2015, 04:58 PM   #14
Crockett's Avatar
Originally Posted by dieselguy View Post
Although the fridge should be reasonably level for any long term use ... level condition has little to do with if the burner lights
thrown in for the benefit of any who read the thread at no extra charge...
Crockett is offline   Reply With Quote
Old 07-11-2015, 05:05 PM   #15
Ford Idaho's Avatar
Originally Posted by CampLife2014 View Post
Hi all. So, the fridge in my 2014 Viking 17FQ works on electricity, but not gas. I tried running on gas one time last year and it worked. But now it just clicks until the check light comes on.
I've looked online and all the symptoms of the issue I can find are rust and debris related. But that isn't the issue here because I keep the vents covered when not in use so it looks brand new in there. Not even so much as a spider's nest.
It's not a big deal, I always get full hook-up sites, more principal. I'll admit that when I have tried the gas mode, my camper was not level at all. Not sure if that makes all the difference of lighting or not lighting.
Thanks!
Make sure the Auto button is pushed to on.
electric, fridge, gas
