Old 09-04-2012, 12:50 PM   #11
B47
Originally Posted by herk7769 View Post
It has been mentioned several times actually. It is a thermistor and sliding it up and down alters the resistance of the semiconductor based on temperature at that point of the fin.
It is colder at the bottom of the fin and it gets warmer closer to the top. By sliding the thermistor towards the bottom the unit will run the refridgerator section "colder"; closer to the top of the fin, it will run it "warmer."
Set it at the location that gets the beer cold; yet won't freeze the eggs.
Yes you are correct -if I had known what it is called I would have done a search.
What you say is 180 degrees from what I as told as far as up being colder and down being warmer, but I am going with what you say.
I guess this is just another little "RV Thing" you learn as you get more into it. I guess we will have to check the position of the thermistor from time to time.
Thanks for your help - Again
Old 09-04-2012, 12:54 PM   #12
TURBS's Avatar
Mines up for colder ?
Old 09-04-2012, 01:03 PM   #13
bob213's Avatar
Coldest part of refrig is low, raising thermister will sense warmer air thus telling the refrig to cool it. Mine says UP for cold.
bob213 is offline   Reply With Quote
Old 09-04-2012, 01:30 PM   #14
Herk7769's Avatar
Yup, checked the manual.
Up for cold.
The fin is warmer up there as I said so it calls for more cold.
Sorry for confusing you.
HAM CALLSIGN - KC3FFW
Old 09-04-2012, 01:34 PM   #15
B47
Up for cold.
No problem - making a mistake here is not something you do often
Good to know that my dealer rep (who told me this) knows what he is talking about.
Thanks again to you and everyone else who came in on this.
Old 09-04-2012, 01:42 PM   #16
Herk7769's Avatar
Mine is perfect in the middle and have not had cause to move it for 3 years.
That memory cell was a casualty of a "Margarita Night."
Old 09-04-2012, 04:14 PM   #17
B47
OK - I have another question now regarding this thermister - we have the cold control buttons on our refrig. Am I correct in assumming that the thermister is controlled by the setting of the cold button?
In other words, changing the cold button setting is the same as moving the thermister up or down without having to actually move it?
Old 09-04-2012, 05:41 PM   #18
Herk7769's Avatar
I don't have that feature, but I assume you don't have the wire clipped to the fins either. My guess is that the buttons do what the wire thermistor does.
Old 09-04-2012, 06:09 PM   #19
B47
The thermistor wire is attached to the cooling fin via a slideable clip so it can be moved up or down. We also have the push button feature, so I am guessing that the button adjusts the resistance value of the thermistor
Old 09-04-2012, 06:10 PM   #20
Herk7769's Avatar
No idea. What is the make and model? I will look it up.
