Old 08-31-2012, 07:55 PM   #1
maxwell18's Avatar
Frig and freezer
I tried to turned my refrigerator on today and it will not get cool, but the freezer is working fine. I thought the two worked together. It is on electric power from the house. I thought if the frig wasn't working the freezer would not also.
The only thing the air conditioning was not on and it was extremly hot in the trailer, but it still has not cooled up after about 4 hrs. the frig I mean. Any on got any ideals?? Need help leaving for trip in the AM.
maxwell18 is offline   Reply With Quote
Old 08-31-2012, 08:01 PM   #2
Give it time, the freezer is the first in the cooling cycle. Remove the outside cover and put a fan on it. Will help considereably.
Old 08-31-2012, 08:02 PM   #3
bikendan's Avatar
there's no way it'll cool in only 4 hrs.!
especially on electric and especially the fridge.
one, propane cools faster than electric and the fridge is bigger than the freezer, therefore takes longer to cool.
do you realize that it cools by absorption and not by a compressor, like the one in your home? cooling by absorption will take all night to get cold, especially on electric. i usually allow for at least 12 hours.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-31-2012, 08:03 PM   #4
Herk7769's Avatar
Yep. 24 hours is about right on electric.
8 hours cool down on propane; much more efficient.
HAM CALLSIGN - KC3FFW
Old 08-31-2012, 08:03 PM   #5
Herk7769's Avatar
LOL
I owe you a coke...
Old 08-31-2012, 11:09 PM   #6
Mountainmanbob's Avatar
I agree
I agree
takes some time
usually I get ours up and running
24 hours befor leaving
a little frost starts to build up in freezer
I know it's cold
and
working for the trip
don't want to find a problem
while out on the road
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 09-04-2012, 11:17 AM   #7
maxwell18's Avatar
Thanks everyone, was late getting started and in a hurry. I usually will crank up the air and the fridge about 2 days ahead of leaving. Thats what I get for getting in a hurry, thanks again. Oh the trip was great!!!!!
Old 09-04-2012, 11:22 AM   #8
TURBS's Avatar
I added one fan inside fridge and two in the vent stack mine now cools down to 32 degrees in the frIdge portion in less than 8 hours.
With the air off as well.
Old 09-04-2012, 11:35 AM   #9
B47
Herk and anyone else -
Our Dometic refrig has a cable on the aft right side (as you face it) that is routed though a slideable cover that is fitted over the most right side cooling fin. The cover can be moved up and down the lenght of the fin and the cable will touch the bottom of the freezer compartment above if so desired.
Someone told me that the cable should be touching the freezer bottom in order for the refrig to be coldest. This cable was thought to be some sort af adjustable thermostat. We did position ours so it touches the freezer bottom and it is much colder than before.
I cannot find any information about this cablemor have I seen it mentioned here.
Is this true?
Old 09-04-2012, 12:25 PM   #10
Herk7769's Avatar
Originally Posted by B47 View Post
I cannot find any information about this cable nor have I seen it mentioned here. Is this true?
It has been mentioned several times actually. It is a thermistor and sliding it up and down alters the resistance of the semiconductor based on temperature at that point of the fin.
It is colder at the bottom of the fin and it gets warmer closer to the top. By sliding the thermistor towards the bottom the unit will run the refridgerator section "colder"; closer to the top of the fin, it will run it "warmer."
Set it at the location that gets the beer cold; yet won't freeze the eggs.
