Old 03-09-2012, 03:21 PM   #1
Frig condensation drain tube?
The condensation drain tube on my Dometic Frig has dry rotted and broken off up where I can just barely touch it. I was told that the frig has to be pulled to replace this tube. Is this true and if so, how hard is it to remove the frig?
bob7794 is offline   Reply With Quote
Old 03-09-2012, 04:16 PM   #2
TURBS's Avatar
Unless you have a weird fridge you should be ably to just pull the outside
panel.
Old 03-09-2012, 05:57 PM   #3
It's not a wierd frig...with the outside panel off I can just barely reach the end of the tube.
Old 03-09-2012, 06:00 PM   #4
MtnGuy's Avatar
You might be able to work that from the inside of the fridge by pulling out the drip tray in back ?? I think the tube is attached directly to that.
Old 03-09-2012, 06:40 PM   #5
bsmall's Avatar
Check out this link: Dometic Refrigerator Drain Hose
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 03-10-2012, 06:20 AM   #6
MtnGuy's Avatar
Good find !!
Old 03-10-2012, 06:20 PM   #7
Thanks for the link Bill. I'm going to give it a shot.
Old 03-12-2012, 10:18 AM   #8
jimh's Avatar
if u have to end up pulling the frig, the biggest part is disconnecting the gas and elect lines. the fridge is screwed in from the front around the outer flange. if u haven't handled one of those friges, u are going to be surprised at how light they are.
jimh is offline   Reply With Quote
Old 03-12-2012, 12:28 PM   #9
bsmall's Avatar
Your welcome, just keep us posted and take some pictures if you can. I am sure this problem will rear its ugly head many times for others here on the forum....
Bill
