Old 06-12-2015, 07:42 AM   #1
StoneyG's Avatar
Frigidaire French Door Refrigerator
We've replaced two refrigerator water filters in 3weeks because of a drop in water pressure to the water and ice maker in the refrigerator and the water flow is low again. Each time I replaced the filter the door water flow increased dramatically and ice production was good. Now neither are good again. I've taken a water softener off line to see if that might be the problem, but the water flow rate still dropped to unsatisfactory rates. I've sent a message to Frigidaire looking for a solution but wonder if any members have had a similar problem that they have solved. Our water pressure on the trailer side of the water filters is about 50lbs.
StoneyG is offline   Reply With Quote
Old 06-12-2015, 09:25 AM   #2
Jim34RL's Avatar
Is this the only filter you have from the campground spigot to the refrigerator?
Just an observation but the filter maybe doing it's work filtering out sediments from the water supply. When the filter plugs the flow rate and pressure will fall off.
That is why engine oil filters have a filter by-pass built into them to prevent engine damage do to lack of lubrication due to filter plugging.
You may want to pre-filter the water first with an in-line filter before entering the camper. This may prolong the refrigerator filters life.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 06-12-2015, 09:29 AM   #3
StoneyG's Avatar
We have a dual canister Flow-Pur filter before the refrigerator so sediment should not be a problem.
Old 06-12-2015, 09:43 AM   #4
mcnabbwr's Avatar
You can eliminate the filter with a bypass plug. I also have a dual filter system so I'm not worried about the fridge filter. Removing it also increased the door water pressure and the ice maker preformed much better. This is what you need depending on model, it's easy to install just like the filter.
Amazon.com: 242294502 - Bypass for WF3CB Filter (Rep. 242069602): Appliances
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 06-12-2015, 10:23 AM   #5
StoneyG's Avatar
I need another model but found it on Frigidaire's web site. That is a great solution. Thanks,
Old 06-12-2015, 08:10 PM   #6
14 CC 38CK's Avatar
Being in appliance repair for many years the filter doesent need to be in the unit to work , I don't install ours I use a filter before water enters the trailer so that I don't have to change the one in the frig. Being they cost so much for so little they do
14 CC 38CK is offline   Reply With Quote
Old 06-12-2015, 08:28 PM   #7
StoneyG's Avatar
So we don't even need the plug to make the water dispenser and ice maker work?
Old 06-12-2015, 08:34 PM   #8
14 CC 38CK's Avatar
No you don't need it , to replace filter you don't have to turn water off , it has an auto bypass built in in most refrigerators , filters are not needed to work
Old 06-12-2015, 08:42 PM   #9
mcnabbwr's Avatar
Next week when I'm at my unit I will give it a try without. I was advised it needed to be in place. Obviously bad information from sales people that's why I purchased the bypass. Thanks for the information, but it brings up a question if it's not required why offer the plug?
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
Old 06-12-2015, 08:57 PM   #10
14 CC 38CK's Avatar
Good question and don't know , I have never put the filter in mine and everything works just fine . Good luck also look up your model on line and see what it says about it .
door, refrigerator
