Originally Posted by Jimmerinwi
The dish stops moving because it locks onto the satellite. Did you hook your receiver to your tv WITHOUT satellite lines connected and run a test. This should take awhile and come back not seeing any satellites. Then, connect coax from dish and run another test. This should finish and show proper satellites. You need to clear the matrix of the receiver before hooking up to the dish.
This is correct, You need to run a Check Switch each time you connect a reciever to the G2. I even sometimes have to run a check switch after I have unplugged the G2 to get it to connect to my Bell receivers.
I use it with 2 recievers and once it's working it is awesome!
Let me know if you have any other questions?
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
