Old 02-09-2019, 08:41 PM   #1
Furnace blower not running
Just got our new TT last week. It's cold, but I'm excited to load my stuff. Fired up the furnace today. Husband thinks blower isn't working. Not a lot of air coming from the vents. Hoping nothing is broken. I did realize that the battery was dead due to a pantry light being left on. Could the dead battery cause the blower not to run? and will this fix itself once we're charged back up?
Thanks.
Lforth is offline   Reply With Quote
Old 02-09-2019, 08:56 PM   #2
koller1509's Avatar
Yes, your furnace runs off of 12 volt system. Plug in and charge the battery and you should be fine.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 02-09-2019, 08:58 PM   #3
Mr. Dan's Avatar
Thanks.
Yes, the furnace blower is a 12 volt motor which means it gets juice from the battery. BTW, the blower has to run fast enough to close a sail switch for the control board to open the gas valve and ignite the gas. If the blower isn't working, the "fire in the hole" isn't working, either.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 02-10-2019, 08:28 PM   #4
Thanks for responses. Battery is fully charged this morning. We turned furnace back on.
There is heat coming from the floor vents, but husband doesn't think it's as strong as our previous camper. We went from a 29ft to a 37 ft TT (3 vents to 4 vents). Would the size cause the airflow to feel reduced? Plan on calling dealership on the morning to ask, but is he just "expecting too much" from this furnace?
Old 02-10-2019, 08:41 PM   #5
Mr. Dan's Avatar
Some owners have found disconnected and/or crushed ducts. I found a metal plate missing from my furnace cabinet. That caused hot air to blow out the air return grate instead of through my ducts. You may have to put eyes on the furnace and ducts.
What kind of trailer do you have?
Old 02-11-2019, 07:01 AM   #6
2019 puma 31fkrk.
We did our walkthrough when we picked up and the heat was on, but neither of us remember checking to see how strong the air was coming from the vent.
Old 02-11-2019, 07:53 AM   #7
cavie's Avatar
Chances are it the same size furnace and yes an extra vent will slow the force of the air flow but not the amount of heat produced. Fast air flow cools off hot air. remove the cover off the inside and look at the furnace as mentioned above but sounds like your over thinking this.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 02-11-2019, 02:27 PM   #8
Adrian Gordon's Avatar
I think my initial approach to this issue might be to get in the trailer, turn on the furnace, set the thermostat to an appropriate temperature and see if the thing gets warm. If it does, great, no problem. If not, then worry about it.
2018 Coachmen Leprachaun 210RS with two large dogs and a cat.
Adrian Gordon is offline   Reply With Quote
Old 02-11-2019, 03:49 PM   #9
Our trailer - 2 vents
our trailer only has 2 heat ducts. One near the rear of the trailer/bath and the other by the front door entrance on the kitchen counter cabinet. Occasionally our furnace will thermal down due to not enough air flow. It is a resettable thermal switch and after a few moments with the burner off it resets and the burner comes back on.
I can't see an easy way to cut a third duct so we will just live with it.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
furnace
