I had the same thing with an Atwood on the maiden voyage 770 miles from home, 730 from the dealer. That was on the 5er in my signature. I called Atwood and they provided the names of several mobile techs. After diagnosis the tech called Atwood support finding no reason for the fuses to blow. OOHHHHhhhh that furnace requires a 15 amp slow-blow fuse. Easy fix if you can find them. I tried auto parts stores, big box hardware, electrical supply and most often found a deer in the headlights stare. Atwood sent a fuse and I ordered 2 more online. Now ~~ working just perfect. It is not a safety issue so no recall and too few to send a service bulletin.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
