Old 06-02-2014, 12:40 PM   #1
Furnace Fuse Location
Hello,
I have a 2005 tent trailer and I am pretty sure I blew the fuse to the furnace The only problem is I am not sure where to look to find it. I am assuming it is an inline fuse on the positive wire for the furnace, but is it located in the furnace compartment (removing the grill) or somewhere else?
Thanks,
Bentwookie
BENTWOOKIE is offline   Reply With Quote
Old 06-02-2014, 12:56 PM   #2
Herk7769's Avatar
The first place to look is in your power center's DC buss (the vertical row of AUTO type fuses on the right). One of them should say "furnace" or some such.
The next place to look is on the floor next to the furnace itself where a current limiter may be located. There should be a button on the short side to reset it. (you may need to take 2 screws out of the fake "grill" and swing the door open).
ID:	54137   Click image for larger version
Name:	913th 3rd Annual Picnic and Camper photos 034.jpg
ID:	54138   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-03-2014, 02:17 PM   #3
Re: Furnace Fuse Location
Hello,
As it turns out there was an inline fuse holder on the red wire connected to the furnace. It was a little hard to get at, but once I found what I was looking for I was determined to get at it. It was easy to open with just a simple twist and low and behold there was a blown 250V 4AMP glass fuse
I guess with the smaller tent trailers the fuse boxes aren't quite so elaborate as yours
Cheers,
Bentwookie
Old 06-03-2014, 02:45 PM   #4
Herk7769's Avatar
Originally Posted by BENTWOOKIE View Post
I guess with the smaller tent trailers the fuse boxes aren't quite so elaborate as yours Cheers, Bentwookie
And less likely to spend a few extra cents to put a resettable limiter instead of a fuse...
cat, furnace, fuse, location
