That looks like a standard female spade connector. It is a crimp connector. Since it's red, it's for 18-22 awg wire.
You can find them at most auto parts stores as well as wally World, Lowes, HD, Agri Supply stores, Etc..
Since it appears to make connection when 'wiggled' I bet the wire inside the insulation is broken. If you try to pull the connector off the wire, is it solid or does it give like a rubber band? If it gives, the wire is broken inside the insulation.
You can cut the connector off the wire and if the break is right at the connector you just need to replace the connector. You can get a pair of cheap wire crimper/cutters from the places mentioned above.
Gotta go campin!
