Old 12-19-2015, 05:42 AM   #1
Furnace issue
Currently on the road in our 2015 legacy. Temps are in the low 30s. Tried to turn the furnace in but thermostats just reads "furnace auto" but no heat coming out. Need help!!!
Michbt is offline   Reply With Quote
Old 12-19-2015, 06:23 AM   #2
arpipeliner's Avatar
Make sure your propane is on. Run the stove burner to purge air out of the line. Turn off the heater and then turn it on might try a couple times. It will reset it self if it didn't get propane the first time. A good place to start. If the stove burner won't light it's probably the safety valve. Or just switch to the other tank. Don't know why but it has worked for me in the past. If a tank is low on propane and cold might not be putting out enough vapor gas.
arpipeliner is offline   Reply With Quote
Old 12-19-2015, 08:48 AM   #3
Ambassador
Ken K.'s Avatar
Yep as above. This is the problem 80% of the time. Happens on my Rockwood all the time. Not only does your propane need to be on, you have to purge the lines...
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
furnace
