Old 10-12-2012, 04:53 AM   #1
Furnace not working
Me n my family are stayin at yogi bear park in md n it's chilly outside n my furnace isn't working. I have a 2006 wildwood 25 ft travel trailer with 2 slide outs. Can anyone help
Poowill is offline   Reply With Quote
Old 10-12-2012, 06:02 AM   #2
realebill's Avatar
propane on,thermostat set to heat, fuse check ???
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 10-12-2012, 06:14 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
LP Detector turned on?
We always carry a small electric heater just in case the furnace would act up.
to the forums. Hope it's something simple.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-12-2012, 06:26 AM   #4
Furnace
All 3 I checked. Is there a pilot light that needs lit? Sorry if this is a dumb question but I'm new to all this
Old 10-12-2012, 06:27 AM   #5
Where's the lp detector?
Old 10-12-2012, 06:35 AM   #6
Not_So_Mini-Lite's Avatar
Sorry but my knowledge is limited but I'll try to help. What furnace does your rig have? I know that in our last two rigs they had an auto ignite pilot (Suburban). It is possible that you may have a spider nest in the tube. Does the igniter "click" like it wants to lite? You should hear several clicking sounds. That is the auto igniter trying to lite the pilot. It may have to do this several times before it actually fires up. I hope this helps you. I'm sure others will step in here and elaborate even further! Good luck!
Not_So_Mini-Lite is offline   Reply With Quote
Old 10-12-2012, 06:37 AM   #7
Ill check the igniter. Thank you
Old 10-12-2012, 09:42 AM   #8
Triguy's Avatar
Depending on your furnace model, you might want to peruse some of the fix it manuals in Files.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-12-2012, 10:26 AM   #9
Herk7769's Avatar
With "furnace not working" as our only clue, it is very difficult to troubleshoot your problem. Here are some files that show how it is supposed to work so you might be more specific as to what is not working.
Name:	Suburban Furnace 001.jpg
HAM CALLSIGN - KC3FFW
Old 10-12-2012, 10:39 AM   #10
Thanks everyone or the knowledge and responses back. I took my thermostat cover off n it was not connecting. So that was the problem. Thanks again evwryone
