Old 04-06-2012, 10:57 AM   #1
Furnace problem
I have a 2012 Puma fifth wheel and am experiencing problems with the furnace. When first turned on, the unit starts and heats as it should. It may even cycle 2 or 3 times properly but then starts to short cycle and /or blow cold air. Before the 2 or 3rd cycle starts the electonic board in the air conditioner clicks off and on several times. The most annoying part of the furnace cycle is when the flame is extinguished there is a small explosion, sometimes strong enough to rattle the door. I had it looked at by a tech this winter and he suggested the propane regulator was faulty as the propane heater and stove all "popped" when being turned off. I replaced the regulator but the problem has not been cured.
Scorp.
scorpion6 is offline   Reply With Quote
Old 04-06-2012, 11:03 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Name:   LP Pressure Gauge.jpg
Did the tech actually test the regulator? Even if a new regulator is installed you'll still need to check the pressure. It should be set at 11" Water Column by using a U-Tube Manometer or a Gas Pressure Gauge.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 04-06-2012, 11:30 AM   #3
dezeldad's Avatar
Sounds very much like an issue I had with my previous trailer. Had the regulator replaced at the dealer under warranty. Problem immediately resurfaced. Did some research and decided to buy a different brand of regulator online and installed it myself ... never had the problem again (kept the trailer another 5 years).
Joe
dezeldad is offline   Reply With Quote
Old 04-06-2012, 02:55 PM   #4
Yes the regulator was checked with a pressure tester and so was the new one, it was not the same brand as the factory installed one.
Scorp.
