Old 02-14-2013, 01:46 PM   #1
Furnace problem
Have a flagstaff pop up camper with furnace. Can't seem to get it to blow how. I plug it it shore power and power everything up, an the furnace blows hard but not cold. The outside vent is putting out fairly hot air. I'm trying to run it electric. I have the green switch and the red switch. I see a flame from the inside of the camper in the furnace and also a flame outside in the box where the switches are. What am I doing wrong. In the box I have the two switches, an igniter and 2 different turn knobs if that helps. Breakers aren't tripped and fuses are good
Killzone is offline   Reply With Quote
Old 02-14-2013, 01:51 PM   #2
TURBS's Avatar
It has electric furnace?
Old 02-14-2013, 01:53 PM   #3
Not quite sure really. I suppose it did bc of the 2 different switches and it says dont turn both on at the same time
Old 02-14-2013, 02:08 PM   #4
TURBS's Avatar
Hmmm.
Maybe I need educated on ur furnace!
Make and model of furnace?
Old 02-14-2013, 02:13 PM   #5
Owner/Operator
RodeoGeorge's Avatar
It looks like the switches that he is describing are the Water Heater Switches.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-14-2013, 02:18 PM   #6
TURBS's Avatar
RodeoGeorge
Wondering that myself!
Hmmmm
Old 02-14-2013, 08:21 PM   #7
bikendan's Avatar
since you don't list the year or model of popup, nor the make and model of the furnace, posting pics of what you're talking about would be very helpful.
that said, your furnace is heated with propane and has no electric heat. you haven't mentioned if you have the tanks full of propane.
the furnace fan is run by 12v power, which can come from the battery or from the converter.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
