Old 10-15-2009, 11:25 AM   #1
Question furnace problem
I have a new 2010 292rl sandpiper that I just purchased in july and the furnace isn't working properly.When you turn it on it runs for a while but before it totally heats the trailer it shuts off, or before it reaches the thermostat temp. Then when it comes on again in a few minutes the furnace turns on and off in about two second intervals a few times then just stays off. When it turns on it does put out heat though. I will end up taking it in I suppose. What do you'all think might be causing that? Thanks
jiffy1947 is offline   Reply With Quote
Old 10-15-2009, 12:18 PM   #2
NWJeeper's Avatar
Jiffy, with our last motorhome I spent a lot of time troubleshooting the furnace, replacing just about every component one at a time until I finally gave up and bought a new furnace. I now have a really good grasp on how RV furnaces are "supposed" to work. I haven't seen or heard of an issue like this one and it sounds to me like it could be a combination of things that aren't working right. Your best bet is to take it in as it is under warranty and when they figure out what's wrong let us know so that if it happens to someone else here we will have an idea of what to look for. Good luck.
Ed & Wendy
www.nwjeepn.com
Old 10-15-2009, 12:22 PM   #3
I would tie the wires for heat together at the stat to eliminate that first. If it still does it my guess would be the valve.
2010 Rockwood 8317ss
2007 GMC Yukon XL Denali 6.2L
Prodigy Brake Controller
Wisconsin Camper is offline   Reply With Quote
Old 10-15-2009, 12:41 PM   #4
Red face
Hi, I will take it in soon and let you'all know what happened. We had never used it at all yet so this is what is from the get go. Thanks guys. Jif
Old 10-21-2009, 11:42 PM   #5
Red face
Well just got the furnace fixed today. F35F suburban. It needed a PC board. They also installed a detachable harness to the furnace. We had only used it once since we bought it early July. Just one of those things I guess.
Old 10-22-2009, 06:39 AM   #6
Head Rambler
Thanks for posting back what the problem was. Infant mortality got it.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
