Old 12-07-2013, 12:29 PM   #1
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Furnace Problem
Hi All: I am having a non start problem. The thermostat calls for heat and I hear the relay on the board click but the fan does not start. Sometimes it will start and run if I cycle the thermostat a few times. Other times this trick will not work and I can't get it to start.
I have checked the thermostat, the sail switch and the over temperature cut off and they are functioning properly. I have not checked the gas valve but I don't think that is the problem. The furnace is going into the third winter. This fall I replaced the fan motor because of bearing noise.
I am thinking of replacing the board. The run sequence starts with the thermostat and then the board and I think the relay is the problem. It is sealed and can not be serviced.The furnace is a Suburban NT-30NP.
Any help is appreciated. Thanks; Frank
Eaglelover is offline   Reply With Quote
Old 12-07-2013, 12:44 PM   #2
Dave_Monica's Avatar
As you're having a very similar problem, you may want to check out this thread... My furnace just clicks
Dave
Old 12-07-2013, 12:50 PM   #3
Phat Phrog
RVChick's Avatar
I feel your pain....or I should say cold...
This is our second winter with our 5er, and the furnace won't work. It works fine in the summer when we have a tech looking into the problem....but as soon as I turn it on in the winter when it's needed, it doesn't work. You can hear the blower, and cold air blows thru, but you never hear the 'click', letting you know the furnace is now blowing. You know that familiar sound.....
The fireplace and additional space heaters, work great....but nothing like the warmth that the furnace would provide. We plan to return to Goshen next year for help from FR. They are amazing!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karenís Camper
RVChick is offline   Reply With Quote
Old 12-07-2013, 12:59 PM   #4
Phat Phrog
RVChick's Avatar
Dave
Great info! Thanks!
Kenny n Karen
Old 12-09-2013, 11:52 AM   #5
Eaglelover's Avatar
Furnace Problem
Thanks to those that replied. The furnace is still doing the same thing. It works for a couple of days and then goes back to clicking until it feels like working again. I ordered a board for $ 113.00 and will install that and see what happens. I hate throwing parts at a problem but in this case I am at a loss. I will check back later. Thanks; Frank
Old 12-10-2013, 09:29 AM   #6
Herk7769's Avatar
You might find the parts you need here:
Furnaces Atwood Suburban Camco RV Designer Camper Trailer RV American RV Company
HAM CALLSIGN - KC3FFW
Old 12-10-2013, 11:08 AM   #7
Eaglelover's Avatar
Furnace Problem
herk7769: Thanks for the link, I will check it out. Frank
furnace
« Dish | Thermostat »
