Old 03-29-2016, 09:44 PM   #1
Furnace question
Hi all, I recently purchase a 2005 Shamrock Hybrid TT. I am set to take it on it's first trip. That being said The over night temps will be in the hi 30's.
I have pluggd in the TT to test the heat and can not get warm air to blow from the furnace.
Is the Furnace Electric or does it requir propane? If propane is required do I need to light a pilot light somewhere or does it automatically ignite some how?
Thanks in advance for any help provided
2005 Shamrock Hybrid 19
ESING is offline   Reply With Quote
Old 03-29-2016, 09:53 PM   #2
Flybob's Avatar
The furnace uses propane to heat and 12V to operate controls and fan. The first time you use the furnace, it may be hard to light. After turning on the propane light the stove and let it run for a minute or two. Next try to start the furnace. It may take two to three tries early on. It will go into a safe mode if it does not light after a few tries. You need to shut off ( not just turn down thermostat) and it will reset. If you have not run the furnace at all yet, I suggest you turn it on an let it run for 20 -30 minutes with the windows open to burn off the oil used during manufacturing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-29-2016, 10:20 PM   #3
Is it blowing cold air or not blowing air at all ?
I don't think you need to worry about burning off any oil used during manufacture unless the furnace has never ran in the 11 years since it was new.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-29-2016, 10:25 PM   #4
Thanks for the replies.
It is blowing out cold air. I have not turned on the propane. I wasnt sure I needed propane. I will turn my tanks purge the lines then try the furnace again.
Old 03-29-2016, 10:44 PM   #5
Ok, follow Flybob's instructions about about turning the stove on and so forth, this will help purge the propane lines of air. You will also need a fully charged battery to hopefully keep the furnace running throughout the night.
2007 Surveyor SV230
Old 03-29-2016, 11:03 PM   #6
Another thing you should do before you go on your maiden voyage is purchase a battery operated CO (carbon monoxide) detector if you are going to run your furnace.
2007 Surveyor SV230
Old 03-29-2016, 11:03 PM   #7
It's amazing what turning on the propane will do. I purged the lines and it fired right up. Nice and Warm! I learned 2 things today propane is my new friend and the exhaust vent gets pretty damn hot lol.
Thank you for the help.
Old 03-29-2016, 11:12 PM   #8
Good to hear that you got it working.
Be sure to get yourself a CO detector.
2007 Surveyor SV230
Old 03-29-2016, 11:38 PM   #9
bikendan's Avatar
Esing, since you are new to hybrids, you might want to check out the Roo/Shamrock sub-forum, in the Hybrids/Expandables section here.
You'll get lots of info and help learning about hybrid TTs and their unique features.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-29-2016, 11:48 PM   #10
Will Do Boondocking. Thanks for the tip.
furnace
