Old 09-27-2016, 12:26 PM   #11
Therma Heat FP18-01R/FP23-02R. How do you change the display temp from C to F?
r.watters1 is offline   Reply With Quote
Old 09-27-2016, 01:36 PM   #12
Here is a photo of the part of the instruction booklet showing the F C settings.
It appears the second paragraph addresses how to change what they call the "temperature converting mode."
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-27-2016, 01:38 PM   #13
*HERE* is a link to the entire manual.
Old 09-29-2016, 08:21 AM   #14
I have the manual it just keeps cycling through the C temps. Ideas?
Old 09-29-2016, 08:36 AM   #15
From what I understand following the directions...
To change 'TEMPERATURE'... press the HEATING button, then press and hold the HEATING button (5 sec.) to cycle between various temperatures.
To change 'TEMPERATURE CONVERTING MODE'... press the HEATING button then press and hold the MAIN POWER BUTTON (5 sec.) to change the LED display from red(F) to green(C) or green(C) to red(F).
Again, I assume they mean F to C (or vice versa) when speaking of the temperature converting mode.
furnace
