08-21-2016, 09:01 AM
Furnace Question
Can someone tell me if the Furnance switch has a breaker that I can turn off or kill power. In my 2016 XLR Thunder bolt the factory installed the ON/OFF Switch that control the AC & Furnance. The problem is when you are walking up the stairs to the bedroom the switch is right where your hand goes when going up. What is happening is the wife accidently hit the AC on to Off and somehow turned furnance on. I don't need furnance so I just as soon turn a breaker off until I needed it. I have checked the breaker box, and all fuses but none identify as Furnance. I assume they must have it tied into the AC breaker. Can anyone chime in and tell me how to de energize the Furnance. When we use our pull camper I never needed a Furnance. NC is way too warm for heat. anyway help appreciated.
Tim in Winterville.
Tim & Rita Coltrain
2021 Chevrolet 3500 Duramax Crew Cab, Allison Tranny.
XLR Thunderbolt 2016
08-21-2016, 09:09 AM
Furnace is 12v so you'll have to pull the fuse not switch a breaker.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "25"
08-21-2016, 09:53 AM
Identify Fuse
See what I see and see if you can identify the right fuse or breaker.
Tim in Winterville NC
Tim & Rita Coltrain
08-21-2016, 10:05 AM
It's a little hard to read but I'm wondering if it's the 2nd 20amp from the top. All I can suggest is pull a few 12v fuses, maybe starting with the 20amp mentioned and see if the furnace is turned off.
As a second thought, could you configure a 'cover" for this switch that would not be in your way and yet allow for protection against accidentally flipping it?
Or, change the switch to a type that is less prone to being accidentally tripped?
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
08-21-2016, 10:09 AM
While its never a good ideal to use a breaker (or fuse) as a switch, temporarily I don't see the harm.
There are secure covered switches that can do the job.
Dorman Conduct-Tite 84815 - Toggle Switch | O'Reilly Auto Parts
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-21-2016, 10:11 AM
This is what it looks like.
Top to Bottom
30 amp E-Bed
20 amp Fuel
20 amp Awn
15 amp Bed
15 amp Bath
15 amp Living
15 amp Kitchen
15 amp Cargo
15 amp Cargo
15 amp Pump
15 amp Flood
15 amp Sterio
15 amp R-Bath
15 amp S/0 or 510
Tim & Rita Coltrain
08-21-2016, 10:13 AM
Yep, it also looked like "Fuel" to me, but it could also be a sloppy "Furn" and 20 amps could be right for a furnace. Mine is 15 amps though...
08-21-2016, 10:23 AM
Picture of Thermostate
Both are in the halway. I assume this is where they normally put them. When the wife goes up the stairs to the bedroom she accidently turned AC off and Furnance on. This is why I need to de engergize.
Tim & Rita Coltrain
08-21-2016, 10:27 AM
How about something like this?
TG512A1009 - Honeywell TG512A1009 - Large Universal Thermostat Guard - Clear Cover
https://www.amazon.com/Honeywell-CG5.../dp/B000BPGP6M
If there is an ugly hole behind it you could use a piece of colored card stock or plastic to cover the hole.
08-21-2016, 10:38 AM
Furnace Question
Depending on how big/brave you are....you COULD forbade her from touching.
2017 Puma 297RLSS
09-27-2016, 12:26 PM
Therma Heat FP18-01R/FP23-02R. How do you change the display temp from C to F?
09-27-2016, 01:36 PM
Here is a photo of the part of the instruction booklet showing the Fº Cº settings.
It appears the second paragraph addresses how to change what they call the "temperature converting mode."
09-27-2016, 01:38 PM
*HERE* is a link to the entire manual.
09-29-2016, 08:21 AM
I have the manual it just keeps cycling through the C temps. Ideas?
09-29-2016, 08:36 AM
From what I understand following the directions...
To change 'TEMPERATURE'... press the HEATING button, then press and hold the HEATING button (5 sec.) to cycle between various temperatures.
To change 'TEMPERATURE CONVERTING MODE'... press the HEATING button then press and hold the MAIN POWER BUTTON (5 sec.) to change the LED display from red(Fº) to green(Cº) or green(Cº) to red(Fº).
Again, I assume they mean Fº to Cº (or vice versa) when speaking of the temperature converting mode.
