Old 05-23-2015, 11:47 AM   #1
member
Furnace quit HELP
Second night in the new camper and the Suburban furnace quit working. Brand new trailer worked fine 1st night 2nd night temperature dropped to 29 C turn the thermostat up and no heat nothing worked. So checked propane full checked power to furnace good everything else seams to be working fine. Then checked thermostat the fuse was blown . Didn't have that one to replace it it was a small one. So knowing I shouldn't do it I jumped the fuse and it kicked the furnace on .now here's the situation midnight temp dropping in the high twenty's .So I did It put tin foil in and jumped the fuse. I KNOW THAT'S A BIG NO NO! but under the circumstances I chose to have heat (Don't forget about DW don't want her cold) . So I let the furnace cycle a few times and it seemed to be fine till next day to get new fuse. Went to bed. Woke up 1 hour later cold .furnace don't work. any help would be appreciated thanks.
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 05-26-2015, 10:03 PM   #2
member
No one has any suggestions? Dealer is 4 weeks out on appointments. Though it might be something simple like a fuse in the furnace or something . Also how can I tell if the T-stat is working or why the fuse blew in the first place
Old 05-26-2015, 10:11 PM   #3
TURBS's Avatar
Make and model of furnace?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "9 nights"
Old 05-26-2015, 10:39 PM   #4
member
Sorry Its a suburban SF 30 F furnace and a Colman Mach t-stat
Old 05-26-2015, 10:52 PM   #5
Assistant TP Supervisor
B and B's Avatar
Your Trailer is brand new, waiting 4 weeks is ludicrous. Maybe a call to Forest River, explain the situation and get a mobile guy to come by and fix it.
I lay odds if it did work at first the fuse bypass trick caused something else to open up. My money is on the thermostat itself. The coleman has a heat anticipator, at least mine does, this is a piece of wire that heats up and moves the spring to stop operation of the mercury switch.
Thread on replacement of thermostat with a digital
Analog Coleman Mach Thermostat
2018 Landmark 365 Louisville with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2017 Heartland Bighorn 3575 Elite 2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-26-2015, 10:56 PM   #6
TURBS's Avatar
Both of those have very good troubleshooting guides on there respective websites.
https://www.google.com/url?sa=t&sour...5oMEBvtAQVKMGg
https://www.google.com/url?sa=t&sour...AWD2H77VX44Kww
TURBS
Old 05-26-2015, 11:11 PM   #7
member
Is there any way to test the thermostat
Old 05-27-2015, 01:33 PM   #8
member
Does anyone know what two wires to cross to bypass the thermostat to start 2 furnace
Old 05-27-2015, 08:12 PM   #9
member
Well you were right I jumped the red and the white wire and the furnace worked perfect so I am replacing it with a digital Colman Mach replacement Thankyou
furnace
