Old 01-04-2019, 12:54 AM   #1
Good Ole Dad
G.O.D.'s Avatar
Furnace Removal
Help. This Furnace is under the Couch. I need to remove it and cannot Figure out How it is Attached to the floor. It Quit working New Years Eve while Camping. So I'm gonna take it Apart. I have been under the Trailer and Discovered it is Sealed. I don't know if it's Glued or Bolted down. [ATTACH][ATTACH][ATTACH]Click image for larger version
ID:	193935   Click image for larger version
ID:	193936   Click image for larger version
G.O.D. is offline   Reply With Quote
Old 01-04-2019, 03:36 AM   #2
cavie's Avatar
remove the front cover and you will find 2 screws holding it down to the floor. You will need to remove the outside vent cover to reinstall.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-04-2019, 09:21 AM   #3
Head Rambler
If you look on page 8 of the Installation Manual You'll see the two screws that should be holding it down.
Gotta go campin!
Old 01-04-2019, 09:31 AM   #4
KyDan's Avatar
It's been a few years since I removed mine but I think you might also have to remove the outside flue cover plate.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 01-04-2019, 09:35 AM   #5
cavie's Avatar
Yep, that needs to come off to reinstall. just did mine this past summer.
Old 01-04-2019, 09:36 AM   #6
Iwannacamp's Avatar
x2 on the screws. On my old unit I had a hard time getting the furnace loosened from the exhaust port. I swore I was gonna tear something up. I guess it was rusted together. It was only like 3 years old and not heavily used, but it was stuck.
You didn't say what was wrong with it. You must disconnect from power to reset...IE remove fuse. Maybe you wont have to remove it.
Mine had a bad board when I plugged and unplugged it started working. Then later I got to put a new board in. Don't forget about the Dinosaur Brand boards if you need one. Good luck.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Iwannacamp is online now   Reply With Quote
furnace
