11-08-2017, 06:16 AM
Furnace runs but no air from vents
The furnace runs and gets hot. There is no air flow from any of the vents. I can feel heat at each vent but no forced air. This is on a 2017 Forest river fr3. These are the round vents that you can’t shut off. The fan on the furnace is running. I am going to assume that the outlet hose supplying the vents is blocked.
11-08-2017, 06:19 AM
Smashed or Not connected! Youroo!!
11-08-2017, 06:35 AM
Round vents ? Most heating vents are rectangle and metal, located on the floor. FR3 different ?
11-08-2017, 06:37 AM
Yep. There are two duct tubes that run from the furnace outlet under the jack knife couch and end near the door. The tubes are hot and I can feel heat from the vents just no air flow.
11-08-2017, 06:39 AM
There’s three more at other end of coach. One in bathroom, bedroom, hallway
11-08-2017, 06:47 AM
I'm with YouRoo then. Tube smashed or disconnected. Possible blockage somewhere ? Fan is running good ?
11-08-2017, 06:51 AM
I remember that you had issues with your "Floor" and they worked on it,did this problem start After the repair work? Youroo!!
11-08-2017, 06:59 AM
The fan runs. I am in the mountains on a hunting trip. Last night I pulled the furnace cover off, outside, and could see the fan running. I am going to try to reach the outlet duct today. If I have to remove the furnace then it’s off to the dealer for more warranty repairs
11-08-2017, 07:01 AM
Did not have to get the floor work done
11-08-2017, 07:57 AM
My previous TT had the rectangular vents in the floor. This '15 Freedom Express 310BHDS has the round vents above the floor at various places. The problem does sound as if the warm air is not being pushed through the 4" flexible tubes. It would be possible that the tubes are bent sharply blocking air flow.
11-08-2017, 08:48 AM
Is there any draw into the return? Put a sheet of paper or toilet paper over the return to see if there is airflow. That will tell you whether the system is completely blocked or not.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
11-08-2017, 09:09 AM
I think I found the problem. I was finally able to get to the outlet tubes, under the floor under the fridge, and found that a cover plate for one of the tubes had vibrated open. It is supposed to be screwed together, but, good old forest river quality assurance was asleep again. I pushed the plate back in place and now the furnace won’t run at all.
11-08-2017, 01:12 PM
It won't run at all, or the fan runs a little while, but it won't fire off?
Is it possible that you got an inlet port cover and closed it? That would prevent the sail switch from making and it won't let the furnace run.
Gotta go campin!
11-08-2017, 01:35 PM
It simply does nothing. Doesn’t even try to start. The electric supply is the same fuse as the fridge and the fridge works fine on gas and electric
11-08-2017, 01:36 PM
It is possible that the vents are still crushed and the pressure blew off the plate you found. If no air or minimal is flowing because ducts are crushed, the sail switch will not operate and the furnace will shut off after initially trying to run.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-08-2017, 01:37 PM
When we got our trailer we had no air flow in the front half. The dealer found one tube under the shower cut and repaired it. Got it back and found it was only marginally better. Ended up searching myself and the end panel on the furnace itself had fallen off. All the heat was blowing into the under bed storage compartment where the furnace was located.
11-08-2017, 01:43 PM
That’s what this was doing.
11-08-2017, 02:00 PM
It could possibly now be in lock-out. (in control board)
Have you tried pulling the fuse for the furnace and cycling the power?
11-08-2017, 02:01 PM
I will try that
11-08-2017, 02:45 PM
Tried it, still nothing
