Old 01-23-2013, 05:39 PM   #1
furnace smell
Lit off my furnace today and I have a heavy after burn smell. Not propane but smell of burning propane. I have never had this smell before, Have not run furnace since last winter. heated camper fine but the smell is horrible. I am thinking of pulling the furnace and checking firebox for leaks. Its a 2008 ultra light and has a surburban heater. Any thoughts before I tear into it tomorrow,
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 01-23-2013, 06:03 PM   #2
Gizmo0706's Avatar
Could it be the smell of the dust burning off from non use? My furnace at home does the same thing at the beginning of the heating season.
Gizmo0706 is offline   Reply With Quote
Old 01-23-2013, 06:12 PM   #3
More than likely it is a "first start up of season smell" It should go away after a bit, if not, I would check it. We get several calls at the beginning of heating season of a foreign odor and it typically is just dust that settles on elements.Never heard of it being called a horrible smell though. Just make sure your CO detector and LP detector and smoke detectors are functioning properly.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 01-23-2013, 06:45 PM   #4
Herk7769's Avatar
Yes, my guess as well.
While there is NO air transfer between the combustion air and the air that gets pushed into the cabin, "hot dust" smells like it is burning. The initial fire up will push the dust that collects on the fan cage and the duct work into the camper.
HAM CALLSIGN - KC3FFW
Old 01-25-2013, 02:58 PM   #5
Well I am stubborn and pulled the furnace. Not a big job anyway. It was very dusty and other than that heat exchanger looked new but dusty. I took a nylon bottle brush and some computer dust blower(which set off the propane alarm) now I know it works. After I cleaned every thing including spiders and webs in the combustion air intake It smells much better and I feel better.Next time I will listen to you guys. I was really concerned that the heat exchanger may be leaking. NOT
Old 01-25-2013, 03:10 PM   #6
Herk7769's Avatar
Well you now have more experience than me with the heater!
I have not had to remove it yet.
Hopefully if I ever have to you will be around to give me some advice!
Old 01-25-2013, 03:17 PM   #7
It is not a big job , out cleaned and back in in 1 hr.( 30 min spent cleaning.)
